โNov-22-2014 10:41 AM
โNov-25-2014 07:48 AM
โNov-24-2014 03:55 PM
โNov-24-2014 01:59 PM
โNov-24-2014 09:33 AM
โNov-24-2014 05:11 AM
โNov-23-2014 02:22 PM
โNov-22-2014 07:09 PM
โNov-22-2014 07:06 PM
JaxDad wrote:Gcworth wrote:
A/C ran this summer (although it wasn't super cold)
Now the compressor will not kick on. The thermostat just keeps clicking and nothing happens. I just replaced all three capacitors today and still nothing. Cleaned the coil with foam cleaner at same time.
Any ideas? Bad thermostat maybe? Fan works when you put to on.
Thanks,
It wasn't very cold, now it won't cycle. If there's low (or no) refrigerant it won't allow the compressor to run so you don't burn it up running the system dry.
โNov-22-2014 07:03 PM
newman fulltimer wrote:Gcworth wrote:
I have the battery turned off. I'm only running the 30A 240V shore power. Where should I test it at to check for the 12.6V? The inverter lugs Or are those still line voltage off the breaker?
ihope your not on 30amp 240 volt if so you have fried things in the trailer
โNov-22-2014 04:12 PM
Thanks,
โNov-22-2014 03:36 PM
โNov-22-2014 02:57 PM
โNov-22-2014 01:59 PM
โNov-22-2014 01:24 PM
