โJan-11-2019 06:16 PM
โJan-27-2019 11:29 AM
pnichols wrote:
However reading in these forums, I'm getting the impression that either late model propane refrigerators are manufactured cheaply or RV manufacturers aren't installing them properly in newer RVs.
โJan-27-2019 10:49 AM
wa8yxm wrote:
Though the logic is not... IN my not very humble opinion valid. WHY did someone say that electric was better if you boondock a lot and propane if parked on a nice level pat at a campground.
Because he does not understand how to level his trailer.
You see Propane needs to be close to level (Generally within 3 Degrees. Does anyone have any idea as to how much OFF LEVEL 3 degrees is.. side to side over 4 1/2 inches. that's 3 slabs of 2X tire width folks)
But electric fridges are good if 3-or even 14 degrees off level (Danger of rollover off level).
Clearly you are not going to be leaving your RV that off level if you plan to sleep in it. SIde to side (I worked it out several times and it's over 3 slabs of 2x lumber no Bouncing down the road by the way it does not matter so much...
I went with Propane.
โJan-26-2019 07:26 PM
โJan-26-2019 02:21 PM
โJan-26-2019 08:21 AM
โJan-26-2019 08:02 AM
โJan-26-2019 07:49 AM
crosscheck wrote:I know when I'm traveling, and have to stop at a Walmart while enroute, there is no substitute for a propane fridge."
โJan-26-2019 07:37 AM
โJan-26-2019 04:03 AM
ajriding wrote:
If you go from house to campground and always camp on the level pads, then propane is best.
If you boondock or travel in the camper a lot parking to sightsee and want to leave fridge on then electric fridge works easier.
โJan-23-2019 07:23 AM
โJan-22-2019 06:49 AM
Dusty R wrote:
During the first energy crunch I took class, at a local community collage, on alternate source of energy. There is was said that Michigan ranked 47th out of the 48 continual states of available sunshine.
Have any of you campers with solar panels camped in Michigan and noticed less power being produced?
Dusty
โJan-22-2019 06:27 AM
โJan-15-2019 01:59 PM
โJan-15-2019 07:42 AM
