ac going on and off
allbrandauto
my roof ac will go on and off only with generator on and engine running have a confort zc thermostat that I have replaced also installed a chock kit on it have no light on the inside when this happens its inconsistent ac blower will run and shut down within 5 seconds and than cycle like that compressor never turn on reset thermostat by pulling fuse doesn't help again will only happen with engine running
4 REPLIES 4
BarabooBob
I don't know about everyone else, but, I don't read posts without punctuation. Those long sentences make my head hurt.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
allbrandauto
thanks mister wizard I think your on the right track with high 12 volt current because this will happen more when I accelerate more than engine idling making the altenator charge more what is the cure for the problem can always wire in a stand alone 12 volt stand alone battery just for traveling when generator is on
SoundGuy
Chances are we'd better understand what you're trying to say if you broke your post into logical sentences ... as it is, a post consisting of one long run on sentence is tough to decipher. Maybe MrWizard understands? :h
2012 Silverado 1500 Crew Cab
MrWizard
Moderator
Moderator
you have a voltage problem on the 12v control circuits
generator on for A/C, converter is on and charging batteries
engine running alternator is also charging batteries
im guessing you have a higher voltage alternator than usual
try un-plugging the converter, flipping off the CB for the converter
this might reduce the 12v circuit voltage enough for things to operate normal
if not you need to look into this voltage situation
I can explain it to you.
1997 F53 Bounder 36s
