โJul-10-2017 04:26 PM
โJul-13-2017 04:21 AM
gbkim wrote:
On my home A/C the compressor start capacitor is usually the one the goes bad most often. I'm on my 3rd one since my new A/C was installed in 2012.
I keep an extra around for easy replacement.
Often the A/C will continue to work while the capacitor is starting to go bad, but the amps drawn when the compressor starts will start to increase.
I usually rely on swapping to a new capacitor as this actually "tests" the capacitor under operating conditions vs testing with a DMM with a capacitor function.
Testing Start Capacitors
http://inspectapedia.com/electric/Motor_Capacitor_Tests.php
If you swapped in a new start cap like a Packard 330V Start Capacitor 53-64 MFD going for about $10, and still having trouble with starting the A/C on the generator, then the soft start might have to be the answer.
Also an AC/DC ammeter like Elenco ST-3030 AC/DC Clamp-on Ammeter is great for seeing amps being used by the A/C (startup, running) as well as DC amps in the 12V system.
Hard Start Kits:
http://www.achrnews.com/articles/120282-mismatched-kits-cause-failures
http://www.achrnews.com/articles/89314-hard-start-devices-insurance-for-the-compressor
Gene
โJul-12-2017 10:51 PM
โJul-12-2017 08:45 PM
LipschitzWrath wrote:
Uh oh, a google search reveals its supposed to be microfarads, in which case that cap is testing fine, too. Shame, I was hoping that was the smoking gun.
The $300 for a Micro-air is starting to look better all the time.
What else can I do? What else could be causing this?
I see the new Coleman hard start cap and PTCR kits are like 108 uF (double what I currently have) . Would a larger cap help or am I grasping?
I tested the existing PTCR for continuity and it came up good. It's supposed to, right?
โJul-12-2017 08:20 PM
โJul-12-2017 06:18 PM
โJul-12-2017 06:09 PM
โJul-12-2017 05:57 PM
โJul-12-2017 03:32 PM
โJul-12-2017 11:55 AM
โJul-12-2017 11:34 AM
โJul-12-2017 11:17 AM
j-d wrote:
You can replace your combination capacitor with two separate ones with the right rating. You need a Jumper to connect one terminal of each to one terminal of the other, forming a "Common"
โJul-12-2017 10:49 AM
โJul-12-2017 08:59 AM
j-d wrote:
You have a 15000 A/C from Recreational Vehicle Products. That's the Coleman brand, and most of those have start assist. InThis Thread, see dougrainer's post. It confirms that your Model Number was built with Start Assist.
I'm glad you posted model number and pix, but your huge pix are giving me a headache. Very hard to get the overall view of the capacitor area. It seems there's a Run Capacitor for Fan and for Compressor, plus a Compressor Start Assist Capacitor and what I think looks like a Potential Relay. If so, that setup is about as good as it gets till you go to a Micro Air unit.
j-d wrote:
The appearance of the capacitor area of your unit, from the pix, makes me think it's far from a new/late model A/C. That opens the possibility of a failed capacitor(s).
j-d wrote:
But... ONE 2kW genny is NOT gonna start a 15000, Start Assist or none. Micro Air? Maybe, but I admit that issue is above my pay grade.
My guess? A good parallel arrangement will get you going. If not, check capacitors.
j-d wrote:
And, NO "extension cords!" An RV extension cable, OK, but you're better to plug your coach right into your parallel genny's.
Please re-size your pix.
โJul-12-2017 04:37 AM
โJul-11-2017 07:30 PM
