Air Conditioner not working and I am desperate
WVmtnhiker
The A/C unit (Dometic) on my new Coachman Apex shut off after running for about 30 seconds. Checked circuit breaker and it is in on position. The manual talks about waiting 2 minutes before restarting the compressor, otherwise compressor will quick cycle and could result in compressor or supply overload. A/C will not restart and I was wondering if there is some sort of a switch or button that must be reset?
Thanks as always for the help,
mtnhiker
11 REPLIES 11
sdianel_-acct_c
There may be a reset process for the thermostat. There is one for our Dometic 5 button Comfort Control Thermostat. Check the manual. We have also unplugged the wire below the thermostat and waited a couple minutes and plugged it back in.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
j-d
Is it a Ducted system, with a Wall-Mount Thermostat, or Non-Duct with controls on the A/C itself? Ducted has a Defrost Sensor that could be out of place and getting too cold too fast. If Wall Thermostat, does it require batteries and are they installed and good?
Golden_HVAC
My guess? Low voltage might have caused the compressor to shut off. IT should have reset in a couple of minutes, and then will be OK ONCE you have higher voltage.
You might also have a bad capacitor, start relay, or wiring.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
profdant139
Same thing happened to me when I used an extension cord that was too long -- too much resistance, I guess.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
westend
Is 12V present on the thermostat?
'03 F-250 4x4 CC
Tachdriver
Here is a how to....
Clicky
Or a thermostat issue?
Terryallan
mtnhiker
Have you checked the breaker on the pedestal? Sometimes they will trip. and you won't know it because the lights still work. My Apex kept tripping the pedestal breaker, I finally had to start running it of the 50A plug. No real problems since.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
RoyB
We are assuming you are at a regular 120VAC pedestal somewhere and not trying to get your air conditioner to work with the 30AMP Shore Power Cable plugged into the 2KW Honda type generator 120VAC receptacle using an RV30A-15A long adapter.
If you are using a camp ground pedestal then you must make sure the camp ground RV 30AMP receptacle is functioning ok and you have the correct 'SAFE ZONE' of 120VAC to run your air conditioner.
We use one of these RV 120VAC plug-in VOLTMETERs inside the trailer close to where we turn ON our air conditioner. If the 120VAC AC is not showing in the GREEN SAFE ZONE on the VOLTMETER we will NOT to try to use the Air Conditioner...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
NHIrish
Does sound like low amperage but insufficient info....
2016 Heartland Bighorn 3270RS
2010 Carriage Cameo 32-FwS
2008 Carriage Cameo
2006 Keystone Cougar
2005 Keystone Zeppelin
1999 Coachmen Catalina
2017 Ford F350 Powerstroke
Curt Q25
Diplomacy is the art of saying 'Nice doggie' until you can find a rock
:W
1492
Moderator
Moderator
Moved from Forum Technical Support
edsland
I would shut breaker off and back on but first turn your water heater to gas if it's on electric. Mine I found out the hard way my first year with trailer that the air and water heater overloads the electric. If that doesn't work make sure you have 110 in your trailer. One time I blew the pedestal breaker and took a while to figure it out. Anytime I'm going to use air I eather shut water heater off or turn to gas, haven't had a problem since.
