โOct-07-2016 12:55 PM
โOct-09-2016 12:15 PM
โOct-08-2016 09:40 AM
โOct-08-2016 09:29 AM
โOct-08-2016 09:12 AM
โOct-08-2016 09:05 AM
TUCQUALA wrote:
Have this mono panel on trailer:
Maximum Power: 150W
Maximum System Voltage: 600V DC (UL)
Optimum Operating Voltage (Vmp): 17.90V
Open-Circuit Voltage (Voc): 22.5V
Optimum Operating Current (Imp): 8.38A
Short-Circuit Current (Isc): 9.05A
Dimensions: 39.5 X 39 X 1.4 In
Weight: 26.5lbs
Using EPsolar Viewstar VS2024BN PWM Solar Battery Charge Controller 20A 12/24V. Looking to add one more of same panel. What would be best: parallel or series?? If serial would be best for battery charging, obviously need to go to a mppt controller. If parallel, would the 20A Viewstar handle a second panel??
Other choice is to add this panel:
Maximum Power: 100W
Optimum Operating Voltage (Vmp): 18.9V
Peak Current (Imp): 5.5A
Open-Circuit Voltage (Voc): 21.08V
Short-Circuit Current (Isc): 6.04A
Connectors: MC4 Connectors
Model:100W Monocrystalline Solar Panel
Cell Type: Monocrystalline
Solar Cell Grade: Grade A
Dimensions: 26.4" X 39.9" X 1.4"
Weight:16.5#
This would fit easily, as would the first, and provide slightly output at less cost. Same questions as above!! Parallel or series?
Thanks in advance!! Will try to answer any necc questions the experts will ask!!
โOct-07-2016 02:09 PM
DrewE wrote:
You mixed up series and parallel here.
โOct-07-2016 02:03 PM
JFNM wrote:
Edit: Sorry, didn't answer all your questions. You can add a second 150 watt panel. If connected in series, you would see a maximum of 22.5 volts and 16.76 (8.38 amps times two). If connected in parallel, you would see a maximum of 45 volts (22.5 volts times two) and 8.38 amps. According to the specs I see for your controller, both are within it's limits. Also remember, panel "max" specs are under ideal conditions which don't exist in the real world.
โOct-07-2016 01:19 PM
โOct-07-2016 01:16 PM
โOct-07-2016 01:10 PM
