Fridge leaking water or something
sunflwrgirl33
Have a 2009 Dutchman Grand Junction with 4 door fridge. Noticing at random times we are getting water in the bottom of our fridge. Have defrosted the freezer to be sure this is not causing problems. Cleaned out fridge and after 3 days we are noticing a little bit of water on bottom fridge again. Does not seem to be wet every day.. possibly every 2-3 days.. Hoping someone has an understanding as to what might be happening.
9 REPLIES 9
Clay_L
The hole in the insert is to limit the flow so the water has time to evaporate in the outside tray.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
sunflwrgirl33
Thank you jetcare!
jetcare
That little black plug has a small hole in it. Pull the plug out, clean the hole and then put the black plug back in.
2016 F-250 Crewcab 6.2L 4x4
2012 Palomino Sabre 32' Travel Trailer
sunflwrgirl33
Oh my goodness! Thank you all so very much! Yes, we now realize we have a tray under those metal fins. There was a chunk of iced over water in there. But more so, my husband drained the water from outside and cleaned up the dirt.
Now the part that is baffling my husband is that there is a rubber piece in the hose that, in his mind, is obstructing the flow of water to be drained. We have lived in our RV for 4 years now and in my mind, I think it belongs there and have told him to replace it. Which he agrees of course. lol
I sometimes get the same thing, water showing up at random times.
On mine, if I keep the door open too long, such as when putting a load of groceries away, I will get water dripping off the fins at the back and collecting where they fall below. Little bits of ice too.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
Old-Biscuit
Beverley&Ken wrote:
In the fridge portion, at back are the fins and under the fins, there is a trough to collect condensation. There is a small tube from this trough to outside to drain the condensation. Any small amount of dirt will plug the tube and the condensation will then drip inside the fridge. Just clean out the tube.
Ken
Open lower outside access vent cover
Inside there is a tube that comes from that drip pan into a drain cup next to burner area.
Condensate drains into cup...warm burner area evaporates condensation in cup
Your fridge also goes thru a 'defrost cycle' every 48-52 hrs.
Fridge shutdowns allowing temps to rise then restarts cooling cycle
If FINS in food compartment are frosty then they will drip allot of water during this cycle
Beverley_Ken
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
sunflwrgirl33
No ice maker. Just standard 2 door fridge on the bottom and 2 door freezer on top.
lj2654
Do you have an icemaker in the freezer? If so they tend to crack after several years on the casings which can cause water leaks.
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
