โMar-01-2020 09:33 AM
โMar-04-2020 02:56 PM
โMar-02-2020 09:14 AM
enblethen wrote:
OP asked about anti-siphon for black water flush. This is also known as a backflow
preventer. It is in-line with the flush line.
It is not an air gap. The tank is vented through the roof.
โMar-02-2020 08:29 AM
โMar-02-2020 07:45 AM
โMar-02-2020 06:01 AM
โMar-02-2020 05:53 AM
Bud
USAF Retired
Pace Arrow
โMar-02-2020 05:04 AM
dougrainer wrote:Cummins12V98 wrote:
Thank you!
Tell you what, If you have the valve removed and have a pipe bypass, SMELL the entry fitting. OR, Overfill the Black tank and see what comes out the entry hose fitting. Yes, it prevents backfeeding to the city water system. But it also stops the odor. Doug
โMar-01-2020 06:04 PM
Cummins12V98 wrote:
Thank you!
โMar-01-2020 05:29 PM
โMar-01-2020 05:21 PM
โMar-01-2020 04:56 PM
Cummins12V98 wrote:dougrainer wrote:
They are installed to prevent holding tank ODOR from venting out the inlet fitting. Most BT flush inlets do NOT have a check valve like the City Water inlet because of the inside Check valve. If the OP's is NOT factory installed, then there is no upper Check Valve. The INLET and the inlet to the tank has a check valve, that comes with the aftermarket BT kit. Doug
They are check valves on the grey and black tank flush lines. They are there to keep contaminated water from siphoning into the public water supply.
Holding tanks vent thru the roof!
โMar-01-2020 03:34 PM
Behind Access panel to my shower valve is where mine WERE as in no longer there! Leakin SOBโs are long gone with PVC fittings in their place.
โMar-01-2020 02:58 PM
โMar-01-2020 01:55 PM
