โFeb-04-2014 03:06 PM
โFeb-07-2014 02:38 PM
KJINTF wrote:Hooked up the cable and program today. Yes, I can see the "live" temp readings from the unit. What would be nice is to watch this as I drive around and see it live. Only way would be to leave the laptop on the dash with a USB extension cord.
Pirate
The data logging will OPEN your eyes to what's really happening
Download the software from the ARP web site along with the many free documents. The controller outputs a data stream via a 5 or 6 pin in line connector, which I belive is a simple RS232 5Vdc data stream. I use an embedded micro processor conversion cable to get USB serial data to the rigs computer system. The controller outputs both a deliminated text file and two MS Excel formated data streams 2003 / 2007. Take a look at the supplied Excel templates which you can easily optimize for your unique situation.
A few degrees off level and **WOW** the temp climbs
โFeb-06-2014 02:49 PM
wa8yxm wrote:The device my be 5 bucks but this builder put it in to a nice package, and nice controller, led display, and documentation for those of us they don't have the time or inclination to do it the cheap way. The price for this wasn't bad at all considering all you get for the money.
The mechinical unit is closer to 5 bucks than 20, it is already on the market, several dozen versions of it, you just need to pick the right temp.. Disc Thermal Switches such as used on high-temp fans and such, i have 4 of them in this Motor home.. Alas, I have no clue as to the proper cut out temp.
I also like to keep it very level.
โFeb-06-2014 09:50 AM
โFeb-06-2014 09:12 AM
โFeb-05-2014 02:38 PM
KJINTF wrote:Hey, I'm not too clear on the data recording. Do you have to have the cable hooked up to a notebook to record?
I'm very impressed with my ARP w/it's data logging capabilities
Logs temps every 2 seconds or so into an excel file - makes it very easy to really see what's happening regarding those temperatures under all conditions.
As stated it's not really a plug and play device.
Not worried about the hundred $'s or so which is less than a 1/2 of a tank of gasoline. My testing/data logging of on-level & off-level operation opened my eyes to the actual temps.
โFeb-05-2014 05:04 AM
โFeb-05-2014 03:48 AM
doughere wrote:Whatever turns you on. I'll say that because of this install, I decided to remove my refer for inspection. I have a wire bundle that travelled up the wall near the top of the flue tube. The insulation outer layer was burned off a 120.v wire. The back of the fridge had burn marks near the top of the tube. So, do they get hot, you bet they do. Until you design and market this simple $20 mechanical limit, this product worked for me. I don't mind paying some extra money for safety.
How many refrigerators fail due to an overheated boiler ??? Not guesses, not estimates, but facts?
Appears to be a severely over-engineered product for its use; a simple high limit control is all this appears to be. If something like this is needed, a simple $20 mechanical limit would do the job just fine.
I'll keep my $120 thank you.
Doug
โFeb-05-2014 03:33 AM
โFeb-05-2014 01:48 AM
โFeb-04-2014 04:11 PM
