Attaching 50amp cables with marine connections
jeffreyhnewby
I have two 50amp cables where one end is a female marine twist connection and the other end is a standard 50amp male plug. For the life of me I can't find a pigtail or conversion device that would allow me to connect them to each other. I believe that would require a female standard plug on one end and a male twist lock on the other. Any suggestions?
34 REPLIES 34
jeffreyhnewby
I guess I should have added that one of my 50amp cables is 30' and the other 15'. I use the 15' one whenever I'm close enough to the post since it weighs much less than the 30' one. However, I have to use the longer one about 25% of the time so I don't want to destroy either one. What I'm trying to figure out is how I can connect these two rather than buy a third cable to use as an extension.
Old-Biscuit
Does your RV have 'twist lock' for power cord?
And you want to connect the TWO 50A cords together .......one plugged into your RV via twist lock and then the other cord connected to that one as an extension cord?
IF so....cut the twist lock off one of the cords and replace it with a standard 50A female plug....then you can plug the 'extension cord' into the male plug on the power cord that is connected to your RV via twist lock
Or just cut the twist locks off both and replace with standard 50A female plugs
enblethen
You could remove the twist lock from one and install a 50 amp range receptacle.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
GordonThree
Nema l6-50r to nema 14-50r
Referring to
https://www.generatorjoe.net/html/web/outlet/quailplug.html
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
GordonThree
Say again? So you need twist lock male to dryer outlet female?
Might have to build it. Home Depot should have these fittings in the electric isle.
