2003 Vintage RV so you have one of the last old style versions (2E/3E)....2004 models were incorporated to a DC Control Circuit
Yours has separate controls, t-stats etc for each heat source
The 120V AC is direct wiring....
AC Power from a Circuit Breaker>>>>>to ON/OFF Switch>>>>>to set of t-stats (normal temp/high temp)>>>>>to element (On/Off switch/t-stats/element---on backside of WH Tank)
15A CB tripped because of a short on the 120V AC circuit....most likely at the t-stats when repair guy was messing around with it with AC Power on
No AC Heating
Tripped Circuit Breaker
Bad t-stats
Bad element (should have continuity between black wire/white wire terminals W/O AC Power ON-------should NOT have continuity between white wire terminal and element flange)
As for t-stat mounting...
From your description the normal and high t-stats are on a mounting plate.
AC wiring goes from one t-stat to other t-stat and plate is mounted to tank wall
With only one mounting not sure if t-stats can be held tight against tank wall...if not the t-stats may not open/close at pre-set temps (N-140*F/H-180*F)
IF you have decent access to backside of WH Tank.......mobile welder/or weld shop----someone that can weld aluminum---and have it fixed
First I would reset that tripped 15A CB...water in WH Tank and try the AC Heating. If it heats then check water temps
If 15A CB trips...then continuity tests thru both t-stats and element
Set of t-stats.....Atwood 90037 (combo set...replaces the individual part numbers)
Combo T-stat KitBolt on element....Atwood 91580
Bolt on styleCourse parts may not be right ones if your model is different then suspected cause you didn't post what model you have?????????
