โMar-09-2020 03:19 AM
โApr-19-2020 11:38 AM
pomology wrote:
Thank you gentlemen for your help! The sail switch recommendation appears to have fixed my problem!
Randy
โMar-29-2020 08:41 AM
โMar-28-2020 10:10 AM
โMar-09-2020 12:06 PM
โMar-09-2020 10:44 AM
โMar-09-2020 09:37 AM
A1RVTraveler wrote:
The problem is with the sail switch bracket. Dometic/Atwood realized they have a problem and redesigned the sail switch and bracket assembly. The new bracket allows the sail switch to travel 1/16-inch farther.
What you currently see is intermittent sail switch operation. The fan motor starts but the circuit board is not getting a signal from the sail switch that it is closed.
The new part number is 33082. You need to change the sail switch AND the bracket. It is covered by warranty if you are in the 2-year warranty period.
Matt
โMar-09-2020 07:26 AM
โMar-09-2020 05:03 AM
โMar-09-2020 04:51 AM
โMar-09-2020 04:26 AM
โMar-09-2020 03:57 AM
โMar-09-2020 03:50 AM
