Atwood Furnace with Flames in Exhaust
rv46
I am posting this on behalf of a friend.
He has a Atwood furnace which appears to work (i.e. blows hot air out the vent). However, he notice that there are some flames coming out of the exhaust. Suggestions?
Thanks.
2005 Ford Excursion (Ninja)
2011 Keystone Bullet Premier 31BHPR (2To)
13 REPLIES 13
mchero
Furnnace needs a good cleaning
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
rv46
Thanks for the suggestions. I have passed them on.
3oaks
My first guess would be inadequate combustion due to air/fuel mix ratio. Often caused by cob-webs or a dead bug or two in the orifice tubing. Usually only takes a little compress air to clear. What needs cleaning is exposed just by taking off the outside vent cover to the furnace.
darsben
rv46 wrote:
Correction, not flames but dark black smoke is coming out. (Sorry for the confusion.)
Since we are long distance troubleshooting a second hand problem. The thick black smoke makes me feel the combustion chamber is plugged up and proper fuel/air ratio not being achieved. He will need to pull the unit and clean it out.
Traveling with my best friend my wife!
rv46
rv46
His RV is a 1996. Unfortunately the "hunting" RV is in Missouri and he is in Alabama. He will be heading up there shortly to fix the issue and was looking for suggestions before he goes. Thanks.
beemerphile1
dougrainer wrote:
Do not use it until it has been checked out by a qualified Technician. Doug
My thought also, shut it down immediately and turn off LPG. Do not use again until serviced by a qualified technician.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Old-Biscuit
Sooted up --- rusty causing 'sparks'
Need to clean combustion/exhaust chamber
2oldman
I'd love to see a pic of that!
rv46
I will pass these questions along. Thanks.
dougrainer
j-d
Another possibility is debris (usually a wasp or mud dauber nest) in the tubes leading to/from the furnace.
No harm in checking, but heed darsben's warning, if the burner is rusted through, exhaust from it can enter the interior of the RV.
darsben
Without enough info the first thing to check is propane pressure and burner orifices. Burner could be rusted out.
Really nee to know how old a unit, any other propane related problems. Was fridge checked for propane operation and does the stove have a proper flame?
