โMay-15-2020 06:08 PM
โMay-17-2020 11:39 AM
Old-Biscuit wrote:
Atwood OEM water heater circuit board is 'encased' in epoxy....
Dinosaur Electronics make a quality board.
But you will also need not just their board but the mounting plate and protective cover cause it is an exposed circuit board and is in the outside compartment/environment
โMay-17-2020 08:52 AM
โMay-17-2020 07:59 AM
โMay-16-2020 06:19 PM
deltabravo wrote:nazpaz wrote:
Thanks for the info. Looks like I need to order a new circuit board!
Check out a company called Dinosaur Electronics. They make really good replacement circuit boards for a lot of different RV appliances.
https://www.dinosaurelectronics.com/
They are way better than the original circuit boards from what I've heard / read.
โMay-16-2020 04:20 PM
โMay-16-2020 07:46 AM
Old-Biscuit wrote:
Circuit Board has shorted........
Both gas and electric use 12VDC for control
DC comes from Electric and/or Gas On/Off Switches to the common circuit board
White wire is from Electric Switch
Orange wire is from Gas Switch
Electric is shorting across to Gas circuit...
**2004 Atwood starting using the 'common DC control' for 6 gal & 10 gal models
โMay-15-2020 08:29 PM
