bad battery, system wont work on 120AC
adkfreeridex
Hey Guys and Gals,
Im relatively new to my trailer (18 foot fleetwood pegasus 2007), and I believe that my battery is beyond salvage. However when Im plugged in to 120AC I still dont have interior lights, pump, etc. I know that the 120AC goes to the power converter to run interior 12V accessories, but will a bad battery keep the system from running on 120? I hope so, otherwise I have bigger problems than a $100 battery.
Thanks!!
15 REPLIES 15
RJsfishin
Sure, buy a new battery,...even if ya don't need one.
Common sense would tell me to start w/ checking the converter voltage.
If the converter is not up to spec, the new battery won't be new for long !
MEXICOWANDERER wrote:
The biggest fault of novice troubleshooting is folks try to start in the middle and work their way to both ends at the same time. 2nd biggest is to assume the problem always lies with the most complicated device.
The battery is bad? Damned if I know how you can outwit that. Start there. New battery. Then see what the symptoms are or are not...
Rich
westend
adkfreeridex wrote:
Wow you guys, I really appreciate all the input. I cant believe how many of you offered your knowledge. My battery was so dead that nothing would work. After being on 120 for 24 hours everything is fully functional. I am going to purchase a new deep cycle for the trip. I think that that with it being so low, it couldn't complete the circuit and the converter would not function.
Do you have a battery disconnect switch and are you using it when parked in storage?
'03 F-250 4x4 CC
adkfreeridex
Bird_Freak
Have you checked your fuses?
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
MEXICOWANDERER
MrWizard
Moderator
Moderator
Mark the cables, then take a picture with your cellphone
Then remove the battery
BTW
Connections at the battery
If cables are
White and black
White is negative/ground , black is positive/plus
If calls are red and black
Red is positive and black is negative
Most likey you have White and black cables at the battery
And that confuses many people and they connect the battery backwards
Before you replace anything
Check the wiring at the battery
If in doubt, follow the wires see where the go, to ground or to inside the RV
The main positive usually goes to a little box with two studs, that is an auto reset thermal circuit breaker approx 40amps, they do go bad , a new one is a few $$ at pep boys etc..
I can explain it to you.
1997 F53 Bounder 36s
ScottG
sfpcservice wrote:
If the battery has an internal short it could cause the converter to trip constantly. I'd remove the battery negative cable, rest the converter and see if it powers up. If so, the battery is the problem.
This.
Every converter will work well enough to power lights (they dont care about ripple/dirty power) without a battery but an internally shorted battery will shut down all 12V.
midnightsadie
X2 and mark those cables before you take them off,and make a drawing, clean all the cables before reinstalling new battery ,and charge the batt before installing.
j-d
Sam Spade wrote:
YOU NEED A METER
AMEN, Sam!
OP - Does your trailer have a Battery Disconnect Switch and Solenoid? If the solenoid's OFF and you don't have Battery to power it ON, then that could be your answer.
Or, you have one and forgot to turn it ON...?
Get a Battery before your burn out a much more expensive converter charger section trying to do CPR on a dead horse.
If the Battery's still connected, please mark all the cables to be sure to get them onto the new one right.
Sam_Spade
All the previous answers could be correct.
YOU NEED A METER to check and see which of them is the right one in this case.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
korbe
Our rig works just fine with the battery turned off and running 12v things through the converter while on shore power. Not sure if a bad battery would keep a converter from operating properly.
DrewE
Some converters don't operate properly without a battery. It's very reasonable to assume that a bad battery could also cause improper operation or non-operation, depending on the battery fault.
Connecting most any known good 12V lead acid battery in temporarily would let you check the converter using a voltmeter. Even something as simple as connecting the trailer electrical system to the truck battery with jumper cables (carefully) should be sufficient to verify the converter output voltage.
Diesel_Camper
RJsfishin
The first thought is that the converter is bad. But that is after all connections have been checked.
If the converter is bad....or bad connection, could that make you think the battery is bad, when really it is the converter not charging ??
If you had a simple thing like a voltmeter, all your questions would be answered
Rich
