โAug-04-2019 02:06 PM
โAug-05-2019 06:29 AM
ItsyRV wrote:Good point - that happened to mine. The city water inlet is the second from bottom white hose on the right in the photo I posted above. A short length of pex then flexible hose. I had to loosen the connections and twist the hose to get the kink out. You can see that it's still a bit restricted but not bad enough to worry about.
If the city water inlet is connected to a flexible hose/tube inside, it's a remote possibility the hose/tube somehow got kinked and is restricting flow.
โAug-04-2019 06:55 PM
โAug-04-2019 06:31 PM
โAug-04-2019 06:12 PM
โAug-04-2019 03:41 PM
โAug-04-2019 02:43 PM
โAug-04-2019 02:36 PM
โAug-04-2019 02:35 PM
โAug-04-2019 02:26 PM
โAug-04-2019 02:20 PM
joebedford wrote:
Was the water pressure still low when you checked your pump after the problem with city water?
โAug-04-2019 02:16 PM
