Jan-23-2021 03:15 PM
Jan-24-2021 05:48 AM
Jan-24-2021 04:44 AM
Bud
USAF Retired
Pace Arrow
Jan-24-2021 03:13 AM
Jan-24-2021 03:05 AM
cavie wrote:enblethen wrote:
I am guessing you have the truck camper with 30 amp shore power and no genset.
I would start by checking the connections in the 120 volt AC power distribution panel.
Pay close attention to the neutrals (white wires) in the back of the panel. I would suggest getting some electrical de-ox grease. Disconnect each wire, one at a time, check for brittle or melted insulation. If there is enough slack cut this portion off. Apply a good coat of de-ox grease, and re-terminate.
Check connections on the circuit breakers in the same manner.
Check the shore power connection in the small junction box. Make sure those are clean and tight. Coat connections in de-ox grease. Your cord may go straight to the 120 volt AC panel.
Careful about using the AC and microwave at the same time.
Check the cord body on the shore power cord for any signs of melting or black blades.
OP stated that he has a transfer switch so not likely a truck camper
Jan-24-2021 03:04 AM
Jan-24-2021 02:59 AM
wa8yxm wrote:
You may have a problem with the A/C. Go topside (up on the roof) and if it's a Coleman (they suck, a good thing) take a good look at the condenser. Is it "Crudded up"? (Yes Remove the outer cover and peal the crud off) 4 screws on top.
most other models. (They blow, more efficient but read one)
Remove the outer cover (Generally around 10 or more screws along the bottom of the cowel) (See note) then remove the inner cover over the condenser (may be a few screws or a major job involving cuttng metal tape and bending tabs) and inspect if needed clean. and re-assemble
NOTE: you may be able to inspect using a mirror without removing the inner cover over the condenser.
Why: If the condender is "Crudded up" it can not shed heat as fast as it is deisgned to, as the heat builds in the A/C's system the pressures rise. the compressor has to work harder and harder, Draws more and more current and ..> Well. Bad things happen. On my 50 amp rig the click of darkness (Tripped breaker) perhaps you are just overloading the generator.
Jan-24-2021 02:40 AM
Jan-24-2021 01:53 AM
3 tons wrote:
I’ll venture a guess or two...
Since this malady happens with either generator (with only a slight variation) I’d look elsewhere...
Since the Microwave begins to cycle off and back on, that’s a huge clue that the 120v power supply is intermittent to the RV’s main breaker panel...This also results in a intermittent power supply to the air cond, causing an overheating condition at the compressor’s passive thermal overload switch - thermal switch subsequently auto-resets...
The ATS switch has a gen-start time delay option (for gen warm-up) of about 15 to say 30 sec - this is normal...But if the power supply to the ATS Switch is intermittent, the time delay will re-occur with each power interruption...
Bottom line is that either the ATS is defective or there is a faulty connection somewhere between the power cord and (or at) the ATS...
JMO,
3 tons
Jan-23-2021 06:00 PM
Jan-23-2021 05:57 PM
HadEnough wrote:OK and low power will not hurt the space heater.time2roll wrote:
Run a 1500w space heater full and continuous and see if you have the same issue.
How old is the air conditioner? May need a clamp-on ammeter to check the draw and compare to specs.
It’s a power issue, not an air conditioning issue
Jan-23-2021 05:42 PM
Jan-23-2021 05:30 PM
Jan-23-2021 05:23 PM
BFL13 wrote:
I thought a lock-up would pull a whole bunch of power and cause what you are seeing.
