โJun-08-2020 02:25 PM
โJun-26-2020 08:48 PM
freetheheal wrote:
to go with 4 175W panels.
โJun-26-2020 07:47 PM
freetheheal wrote:
Well there are a lot more considerations and opinions on solar than I imagined. What I ultimately decided was to go with 4 175W panels. There will be 2 at the very back on each side of the vent. Then one in front of the vent situated perpendicular to the trailer. And then one more between the A/C and the vent in the middle of the trailer. These will be installed in parallel and running 8awg wire from the panels to the combiner box that is at the front. From the combiner box I'm going to go through the roof and straight down to the charge controller with 4awg. We use the trailer quite a bit in the winter so hopefully this will be enough to let us dry camp without the generator for 4 or 5 days. Right now we can go about 2 days in the winter without the generator.
โJun-26-2020 05:45 PM
โJun-26-2020 05:07 PM
pianotuna wrote:
#8 is overkill for a series install.
โJun-26-2020 08:28 AM
โJun-25-2020 05:10 PM
โJun-15-2020 01:47 PM
โJun-15-2020 09:22 AM
BFL13 wrote:I don't know, but when going solar I think it's best to do everything to avoid shade, not make it a factor in installation.
In series the added panel is still going to be at the lowest amps same as the shaded panel; in parallel it could be more panel not in the shade so it does its full amount?
โJun-15-2020 09:17 AM
โJun-15-2020 09:05 AM
freetheheal wrote:You will still be losing amps. Or you could ditch the vent covers.
I'd like to run the panels in parallel because I think I will always be dealing with shade issues from the vent covers.
โJun-14-2020 06:04 AM
โJun-13-2020 08:38 AM
โJun-12-2020 03:40 PM
โJun-12-2020 01:34 PM
