Bathroom vent cover stuck in up position...
cannesdo
When I toggle button up or down it makes the usual "Rrrrrrrr" sound but the vent cover doesn't move. Any ideas what's broken and needs replacing?
thanks!
Jen
2 REPLIES 2
Dick_B
Was that suggested by a fellow RVer that you had a screw loose?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
cannesdo
Problem solved. There was a screw loose on the underside of the lift mechanism causing the gear to drop. Tightened that up and it works normally again. When I removed the screen from the inside the gear dropped down on top of it. Looked normal from above (the roof) though.
