โOct-25-2013 09:10 PM
โOct-27-2013 01:39 PM
tvfrfireman wrote:
I am losing about 15% of my charge every week and the batteries are a year old.
โOct-27-2013 01:14 PM
โOct-27-2013 01:10 PM
tvfrfireman wrote:Sounds like you have a significant parasitic load on your batteries or like someone else mentioned, your batteries are shot. Remove the batteries from the RV and FULLY charge them separately with a portable charger (probably will take a few days), then let them sit overnight with NOTHING connected, measure the voltage afterwards.
โOct-27-2013 12:23 PM
smkettner wrote:Thanks for your response. I have 600 watts of solar but am under a roof. I am losing about 15% of my charge every week and the batteries are a year old.
If the pump has a direct switch it will not be draining the batteries. If it has an electronic control or relay then anything is possible.
Otherwise AGM will still self discharge 1% or 2% per month. I suspect the battery may not be fully charged. The surface charge may give an illusion of full charge. Really needs to be held close to 14.5 volts until current drops to about 1/2 amp or less.
Another alternative is to add 60 to 120 watts of solar and a good controller.
โOct-26-2013 05:24 AM
โOct-26-2013 02:59 AM
โOct-25-2013 10:18 PM
โOct-25-2013 09:47 PM
