โMar-18-2022 04:32 PM
โMar-21-2022 05:49 AM
โMar-21-2022 05:34 AM
Veebyes wrote:StirCrazy wrote:
I just leave them plugged in year round with a good charging unit in the rv.
And risk the charging unit failing & perhaps failing & overcharging the battery bank, trashing the batteries? No thanks.
If the unit is stored at home where you keep a constant eye on it then fine, leave it on if it makes you feel better. If it is stored remotely where you don't get to it for weeks, months even, better to disconnect & leave the unit completely dead for storage.
No risk of the charger failing that way.
I get to see my unit for the first time since last October in three weeks time. It has been stored completely dead since then. With the exception of a little self discharging over winter, I expect the battery bank to be just fine & will be 100% in a half hour or so of power being restored to it.
Much is made of leaving batteries on trickle chargers by RVers, but look around. Farmers leave equipment for months without use, no chargers. Boaters leave boats on moorings for months unused, no chargers. Construction equipment sits unused for months, no chargers. All kinds of other vehicles sit for months in lots unused. No chargers.
RVs can certainly do the same.
โMar-20-2022 07:49 AM
Gjac wrote:Commonly the same as when the battery was bought new.
> Batteries sat for 5 months without charge
โMar-20-2022 06:44 AM
โMar-20-2022 06:36 AM
โMar-20-2022 06:20 AM
wa8yxm wrote:On the contrary my batteries are 15 years old. 95% of my camping is dry camping. Only charge by alternator or when I get home but never leave on constant charge when home always disconnect. I believe leaving them on constant charge eats away the plates faster than just recharging when they reach 80-90% SOC.
On a guess I'd say your batteries are
1: Fairly new
2: Still very good.
Self discharge will increase over time
And the advice to all who have batteries which may have sat a bit longer than they are comfortable with.
Charge 'em up and see how they perform.. Worst case. they need replacement. Best case. they don't. IN FLOODED wet cells check if they need Distilled water added first and add to about 1/4 to 1/2 inch BELOW the bottom of the filler tube (Split ring) not to the bottom of it.. over fill they tend to Spit at you. they spit acid.
โMar-20-2022 05:35 AM
โMar-19-2022 01:31 PM
โMar-19-2022 09:15 AM
Lwiddis wrote:
You were lucky. Batteries appear to have survived. Low self discharge is one Lithium advantage.
โMar-19-2022 08:09 AM
Trackrig wrote:What is the state of charge after sitting for a year? Cold weather definitely helps.
My batteries in my hunting rig only get used in September. At the end of Sept they're fully charged, hit the disconnect switch and they're good until next Sept after sitting in the rig as far down as -60F during the winter. The last set of Interstates I changed out after 7 years and I expect to get the same out of this set.
โMar-19-2022 06:22 AM
โMar-19-2022 05:52 AM
โMar-19-2022 05:46 AM
โMar-18-2022 06:43 PM
