Battery Disconnect?
ronmc
On reading info. on battery disconnect, it says to disconnect battery if it will be on converter power for extended time.Anyone do this? Mine stays on shore power/ converter power for months. Am I ruining my batteries?
Ron
2002 Kountry Star
2007 Honda CRV
Used Brake Buddy
22 REPLIES 22
RoyB
I think I would disconnect from shore power and let it set a few minutes and then measure DC VOLTAGE at the battery terminals... Should read 12.6-7VDC if fully charged... If it starts dropping down below 12.0VDC rather quick then your battery is toast I suspect...
Here is a good chart showing voltage level verses charge state...
Never heard of putting mineral oil in a battery... Must be an old timers trick... MEX probably will have a good response to that haha...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
RJsfishin
Owie !
I would not be running 13.6v when the real hot weather arrives.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
ronmc
The converter supplies 13.6 volts continuously
I used to add water each month,I added mineral oil. Now much less.
Ron
2002 Kountry Star
2007 Honda CRV
Used Brake Buddy
time2roll
Please post the voltage on the battery terminals.
How often do you add water?
MEXICOWANDERER
Lack of STICKIES syndrome
Repetition Ad Nauseum...
2oldman
downtheroad
Depends on the type of converter you have...
If it has a "maintain" or "float" stage then it does not need to be disconnected.
This "float" stage will maintain you batteries at full charge without "boiling" them or damaging them.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
RoyB
If your 2002 trailer does not have the smart mode converter/charger chances are you may be boiling out your battery fluids over time. They don't do well with a constant 13.6VDC voltage on them for long periods of time.
If you leave it connected just be sure to keep a close check on the battery fluids...
Roy Ken
Roy - Carolyn
