Battery Isolator - Parasitic Current
otrfun
Does the typical battery isolator subject the vehicle battery to any parasitic current when they're in the "cut-out" mode (secondary battery disconnected)?
20 REPLIES 20
otrfun
MEXICOWANDERER wrote:
ISOLATOR covers a large territory. Which type do you have??
Havenโ€™t purchased one yet. This isolator (and many rebranded versions of it) appear to be very popular on Amazon.
wa8yxm
There are two basic types of battery isolators and on one of them two control systems
Diode isolators have no control system bit it is possible they may present a tiny "leakage" current.. I doubt you'd be able to measure it it's that small.
Relay isolators when isolated it's 100 percent no leakage but the control system may have a voltage sensor that "draws again a very tiny amount a very very tiny amount.
pianotuna
Nomad II
Nomad II
Some folks use a Trik-l-Start to maintain the Chassis battery.
Regards, Don
pianotuna
Nomad II
Nomad II
If the isolator is a relay, or solenoid, then no.
Regards, Don
MEXICOWANDERER
BFL13
With the ignition off, the isolator keeps all house loads from the starting battery. BUT the starting battery still has its own parasitic loads on it from the engine computer , dash clock etc.
Some put a small charger on the starting battery to maintain it while the RV is parked and isolator is "open", while the house batts are maintained by something else.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
