Thanks everybody for all of the great responses so far. You have all given me a good list of issues/corrections to consider. I'll add a few things for clarification that I missed in my original post.
- I did top up the water in my batteries before I started monitoring this issue. They took a bit but weren't that low. No cells were exposed.
- When I say that I took readings from my display/meter, I am referring to the display unit that is hooked to my solar controller. Not the useless LED battery meter that comes standard on all campers.
- My display measures SOC as well as Voltage. It does take into account the battery capacity (which is setup based on the amount of AH I set in the controller)
- In all tests that I've done, the voltage on my display seems to directly match up with what I get on my voltmeter with everything disconnected from the batteries.
- When I spoke of seeing 13.0V the other night, I should add that this was just after sun down. So the controller was in "Night Mode" (Not Charging) but the batteries hadn't had time to properly settle. But when they do settle they settle around the 12.6-12.8V mark (which is 100%). That voltage doesn't seem to drop abnormally when loads are placed on the system. It's just the SOC that does.
- I have definitely not ruled out the idea that my display/monitor has gone defective. The only reason that I'm not jumping to that conclusion right away is because it did charge to 100% SOC and rest there in the past with the same setup. Of course, there is no telling when things will go defective.
- The hydrometer test is something that I have not done yet. I guess I don't trust the cheap testers that you buy for $20. And I don't really want to fork out the amount to buy a proper tester as they are not cheap.
- When I completely disconnect all 3 batteries and measure them, they all give the same voltage reading (they only differ by a matter of hundredths of Volts).
In the past I have read that sulphated batteries can show a proper voltage, but will read at less capacity (which my monitor is likely capable of reading) or a lower SOC. Can anybody comment on this? I'm okay with buying new batteries if that is in fact the issue. But on the same token I don't want to replace good batteries with good batteries. If I wasn't getting good battery life anymore than it would be a no brainer. My battery bank was more than sufficient before, so it is possible that I have lost capacity but haven't realized it. But the fact that they still seem to last pretty good is what has me confused. I guess one easy way to test would be to take a known good battery and hook it up in place of the others and see what happens.
KZ Inferno 3812 5th Wheel Toy Hauler
12' Garage, 3x12V Group27 Batteries, 250w 24v Solar Panel, 3000w Inverter, Kegerator
2013 Silverado 2500HD LTZ
Duramax/Allison, EFI Live, 4" FloPro, S&B, Edge CTS, Fully Deleted, Ride Rite Bags, Curt Q20
