Best Cleanser for Condenser Cleaning for AC?
jodeb720
I did a search - and there's a host of answers.
the most common were 409 cleaner, Dawn dishwashing soap, Simple Green.
What's the most effective cleaner to remove all the crud from the condenser/eveaporator?
Thanks
Josh
13 REPLIES 13
zee09
Thank you for sharing to save my time.
udidwht
Use this...
https://www.amazon.com/Cleaner-Ounce-Aerosol-Clear-Yellow/dp/B099J9YRMY
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
Flight System Generator man 360 (PM me)
jjrbus
I have asked a few times about simple green, there is simple green and simple green foaming coil cleaner. Which one are the experts using??? Never got an answer??
VINEGAR!!!! OMG
Huntindog
Read the labels. Anything with petroleum in it can harm the roof.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
wolfe10
Any box store will have aluminum-friendly condenser/evaporator cleaner.
Rinse with fresh water.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
schlep1967
I used this and it worked great and it's cheap at the local Wally World.
Condenser cleaner
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
jodeb720
@OldWizard,won't the acid in the vinegar corrode the fins?
Thanks guys. I took the 5er back to night - almost done with my floor - but I know the AC unit needs a good cleaning!
That's next weekend.
theoldwizard1
Vinegar ! Spray it on, let it sit 10-15 minutes and hose it off.
Lynnmor
Since you are dealing with thin aluminum parts that are holding high pressure, it would be best to use a product that won't promote corrosion.
DrewE
An old toothbrush or something similar to scrub with (carefully) can also be helpful.
opnspaces
Navigator
Navigator
Never cleaned mine because have only ever ran it maybe 5 times in the last 16 years. But I would just use plain water from the garden hose. All you're cleaning off is dust and dirt. There's no oil or other adhesives on there to require an actual cleaning agent other than water.
jdc1
Tyler0215 wrote:
Water
Ditto. Regular household water pressure. No pressure washer!
Tyler0215
Water
