โNov-04-2018 01:23 AM
โNov-04-2018 06:30 PM
mrad wrote:time2roll wrote:
http://www.bestconverter.com/Replacement-Lower-Converter-Assembly-for-WFCO
I would just go with the 45 amp.
Are you telling me the one I have is not a good one? I have no problem buyinga new one if that is the case, however, after reading the responses, it sounds like my biggest issue may be how I treat the battery in the winter
โNov-04-2018 05:08 PM
โNov-04-2018 02:43 PM
โNov-04-2018 02:32 PM
mrad wrote:
World Friendship CO. LTD . Model WF-8965
โNov-04-2018 02:20 PM
pianotuna wrote:
What we are trying to get through to you is that in the past the batteries were never fully charged.
โNov-04-2018 01:53 PM
โNov-04-2018 01:42 PM
โNov-04-2018 01:40 PM
mrad wrote:Yes the WFCO does advertise that it s a multistage converter however in practice it is much closer to a fixed 13.6 volt trickle charger.
โNov-04-2018 12:49 PM
MEXICOWANDERER wrote:
2018 Deep cycle car car batteries are nothing more or less than 1960's engine starting batteries. A 2018 Trojan group 27 is equal to a 1968 Ford Autolite group 27 heavy-duty car battery -- plate wise, plate thickness and overall battery weight. Ain't Life Grand? The 60's 8-D was a hell of a good 23 plate per cell battery.
Try this on for perspective for a battery bank on ground usage. A huge bank of engine starting batteries limited to 80% depth of remaining charge would make a fine bank. Too much cable to contend with but what the heck.
Everyone states they hate to use a hydrometer
OK Use a substitute
Your wallet
โNov-04-2018 12:44 PM
โNov-04-2018 12:26 PM
โNov-04-2018 12:15 PM
time2roll wrote:mrad wrote:Open the breaker/fuse panel and post the model number.
Not sure. Where would I look for this?
Probably a WFCO again chronically undercharging the battery.
โNov-04-2018 12:11 PM
โNov-04-2018 12:09 PM
OK I need more info. You are stating the Vector has no float or was configured to default to never go less than 2.2 amperes charge rate. The Vector is capable of continuous 2.2 amperes output?
โNov-04-2018 11:44 AM
mrad wrote:MEXICOWANDERER wrote:
You were doing multiple things wrong. Incomplete charging will kill a battery faster than overdischarge and complete recharging.
Mex,
To teh best of my knowledge, I almost always put a full charge back into it according to my vector smart charger. if it wasnt full, the charger was at least in trickle (2.2 amp charge) mode.
The batteries were always labeled deep cycle. The interstate ones also had a pic of a boat and RV on them next to the deep cycle label.
