Best range/oven to purchase?
groundhogy
Ive got a 22โ€, 3 burner Amana range/oven. I think its sold with other names stamped on it too. Looks like this..
https://www.plessers.com/Amana/aly2280bds.htm
Have continuously had problems with the pilot going out and the oven shutting down.
Temperature control is also not accurate, but i have a Fluke multimeter that measures temperature for that.
Wife bought all kinds of stuff for a big baking day today...
Yup, cant keep her lit again. Ive set pilot high, med, low. Sometimes soots up the pilot temp sensor.
WHAT IS A GOOD RELIABLE OVEN TO BUY?
16 REPLIES 16
Veebyes
We had to replace our stove last year simply because of the lack of a small part. Not thrilled at all about having to get a new stove.
The biggest problem was getting a replacement to fit. You would think that the manufacturers would get together & agree on a few overall dimension sizes, but no, that is not the case.
The best available was the same depth & width but not height, losing oven capacity. The DW is not happy with it.
If buying a replacement do not assume anything. From the start know your dimensions.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
Tom_M1
My coach came with a Panasonic combination microwave/convection oven. The convection part works amazingly well for baking. I can fit up to a 13 pound turkey in it. The down side is that it uses lots of power and I either need to run my generator or be plugged into shore power.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
