โDec-09-2015 01:33 PM
โDec-15-2015 10:01 AM
Almot wrote:Was looking for the best/cheapest source for water pumps......Skid Row Joe wrote:
What's a DVM?? See above ^^^^ post. Water pump has green light indicating a complete circuit. Do you have a source for water pumps that you can recommend?
DVM is the same as multimeter, for your purposes.
Green light doesn't indicate proper voltage.
There are "dozens" sources for RV parts. Just use Google. Here is one:
PPL motor homes
โDec-11-2015 05:02 PM
โDec-11-2015 03:32 PM
Skid Row Joe wrote:
What's a DVM??
โDec-11-2015 03:24 PM
โDec-11-2015 02:35 PM
Old-Biscuit wrote:There's a new application part # with the same GPM rating as before. Where have you sourced water pumps is what I'm down to now?
Shurflo 2093 is a Whisper King model. Part of the Classic Series
30psi discharge/ 2 gpm flow rate
Whisper King info/parts break down
Shurflo has 'discontinued' the Classic and Extreme Series
Some 2093 pumps are still available from vendors old stock and replacement parts also.
But if you should have to replace.
Go with the 4008 Revolution Series.
55psi and 3 gpm
LINK
โDec-11-2015 02:34 PM
SoundGuy wrote:What's a DVM?? See above ^^^^ post. Water pump has green light indicating a complete circuit. Do you have a source for water pumps that you can recommend?
I wouldn't necessarily assume the pump itself has failed ... "green light" means nothing when we have no idea where in the circuit it's located. I sure wouldn't be buying a new pump until I knew for a fact that +/- 12 vdc was actually reaching the pump so the first step is to check with a DVM.
โDec-11-2015 02:33 PM
Almot wrote:The green light indicates a completed circuit. The water pump isn't operating. The screw on black plastic with clear indicator viewer is on every water pump body - you cannot miss them.
This is not the kind of "green light" that one should trust or obey. Take a multimeter to pump and report back.
I had my pump "failing", sort of. Motor running, no water flowing. Turned out to be debris in intake filter and air leak in the pump housing. It only needed cleaning and re-tightening.
But, by all means, go ahead and buy if you think you have to, keep China happy.
I don't know what is a "screw-on black plastic". If it's a hose fitting, and it's not broken, then disconnect and reuse it. Intake filter you remove, inspect and clean and again - if it's not broken, then reuse it.
โDec-09-2015 09:37 PM
โDec-09-2015 06:45 PM
โDec-09-2015 05:33 PM
