โJul-07-2019 12:37 PM
โJul-08-2019 07:38 PM
โJul-08-2019 04:05 PM
โJul-08-2019 11:44 AM
DFord wrote:
mnoeltne,
You've never reacted to my earlier advice about keeping the black tank dump valve closed until the tank is near full. If you're doing that, you won't be able to see the bottom of the tank. If you're leaving the valve open, you're asking for the kind of trouble you're reporting here.
So which is it?
โJul-08-2019 06:18 AM
โJul-08-2019 04:08 AM
mnoeltne wrote:Acampingwewillgo wrote:
Just for kicks, do you use LOTS of water when flushing the throne! Not speaking of while cleaning but rather in just the everyday flushing the toilet. I know I will always fill the bowl fairly well before stepping on the pedal to flush. I realize if you are someplace without sewer then doing this might fill the tanks quickly.
We try to, although that is part of the reason I'm changing the blade seal. Usually there isn't a whole lot of water in the bowl, but we do hold the flush lever open to let more water down in there.
So, I'm sure that this at least part of the issue, but the rough texture of the surface is certainly not letting stuff run off down into the tank easily.
โJul-08-2019 03:56 AM
DFord wrote:
Never BUT NEVER! camp with your black tank drain open!!!!!!!!!!!
ALWAYS!!!!! Allow the black tank to fill to almost full before dumping!!
IF YOU CHOOSE NOT TO FOLLOW THESE STEPS, YOUR SOLIDS WILL MOUND UP!!!
Just like you're describing here. After flushing the tank ALWAYS allow it to fill with enough water to cover the bottom of the tank to prevent the next toilet flush from sticking to the bottom of the tank.
If you follow these hard and fast rules, you will not have any problem with mounds of solids and TP building up in your tank.
RVs are not flush toilets like you have in your house where over a gallon and a half of water move the solids along towards the septic tank or sewer treatment plant with each flush.
I use and recommend HIGHLY a tank treatment called "HAPPY CAMPER" every time I empty my tank. It helps dissolve TP and breakdown the solid but most of all kills the odors. After flushing the tank, fill the bowl, put a scoop of HAPPY CAMPER in the toilet and use your bowl brush to swirl it around to mix it up and clean the inside of the bowl and lip wiping off any excess. Then flush the toilet, fill it again to rinse your bowl and brush before putting thinks away and returning the toilet to use. http://1-happycamper.com/ Use this link to read more about the product. You can find it offered by several vendors on the internet, Amazon and Ebay plus "good" RV supply stores. Shop around.
โJul-08-2019 12:36 AM
โJul-07-2019 10:05 PM
โJul-07-2019 09:12 PM
โJul-07-2019 08:54 PM
โJul-07-2019 07:19 PM
โJul-07-2019 07:13 PM
โJul-07-2019 06:18 PM
Old-Biscuit wrote:
Typically waste tanks are sloped...shallow end under inlet pipe.
Whenever using TP you should FILL the toilet bowl FULL prior to flushing so you have good volume to carry stuff away from inlet area
Just the nature of gravity toilets.
Shorter the drop the more likelihood stuff will collect if NOT using enough water when flushing
maddog348 wrote:
If NOT really full before using ~ do your thing ~ hold pedal down 1/2 way (lets water in none out)~ fill to top with water ~~ FLUSH
โJul-07-2019 06:01 PM
