I recently purchased a fw camper and found out the other day that my black water valve had a slow drip. I looked at it closer to see the bolts that hold the valve to the flange, which is glue to an elbow, has 2 of the 4 mounting tabs broken off. Its the 2 bottom bolt tabs, the bolts are very badly rusted and have cracked the tabs off and the holes the bolts go thru in the valve are busted also. I don't know where to start..... It looks like the 4 bolt flange that the valve bolts to is glued to the elbow so I can't just cut it out and glue a new one in.
Am I going to have to replace the tank????
Do they make any kind of rubber adapter to go over the elbow and the connect to a new valve mounting flange?
I have a plastic welder and can use it pretty good, I was thinking about cutting out the old valve and welding a new one to the elbow.
Any thoughts?
Anyone had this happen to them?
Thanks in advance for any help you can offer.
Mark
99 Dodge 3500 DRW, 5 sp, CTD, Power upgrades, Jake Brake,
Firestone Ride-Rite airbags, Rancho rear shocks,
20' Bayliner toy, 2002 Lance 1121, Let The Fun Begin!
