Bobbo wrote:
A solid check engine light means check the codes whenever it is convenient.
A blinking check engine light means pull over, stop and call a tow truck.
No, not even close.
Blinking CEL is a DETECTED FAULT IN THE EMISSIONS SYSTEM, this MAY set a code but most of the time it will set a pending code if fault condition clears before the next cycle.
If the fault clears before the cycle then blinking goes out and no code is set (there may or may not be a pending code),
If fault persists into the next cycle then the CEL light is turned on (solid, no blinking) and the code is set..
IF code has been set you have two different routes, a temporary code and a permanent code.
Temporary code will clear it's self IF the fault no longer exists after 3 or more full ignition cycles (engine runs until it is fully warmed up then shut down and allowed to cool).
Permanent CEL code will not clear without the use of a OBD reader.
Just because you have a blinking CEL or full on CEL does not mean you must stop and have it towed.. It simply means there has been a emissions related fault detected and you should see about getting it serviced soon..
Now, continual operation with a lit CEL could cause damage to the CATS or Oxy sensors PROVIDED you have a over lean or over rich fuel condition..
The best tool to own now days is a full on OBD reader (I am NOT talking about those Blue Tooth dongles)..
A full dedicated code reader WILL not only read the codes but has built in dictionary of the codes it reads.. This makes troubleshooting much easier.
Those BlueTooth dongles will often give you a code, but then you will have to do an Internet search to find out exactly what the code means.
If you have a Harbor Freight store near you, they have multiple code readers.. They actually are a real good deal and work well.. With 20% coupon you can get the top of the line HF reader for about $112 and it reads engine codes plus ABS codes and the newest models also read the CANBUS communications codes as well..
If money is a problem they do have more basic models starting at $49 but be aware some cheaper models can not remove codes and reset to CEL light. Best to read the manuals before buying (hint, HF does have the manuals online so you can read them before buying!)
