โJun-22-2013 04:11 PM
โJun-23-2013 08:35 PM
โJun-23-2013 02:22 PM
โJun-23-2013 02:11 PM
โJun-23-2013 02:02 PM
Dr Quick wrote:
Try this. Use a test light to connect two sides of fuse holder, If light is on you have a direct short. Start to pull fuses and jiggle wires to see if you can get light to go out. When light goes out you found the problem area. Also if intensity of light varies, you are in the right place. You may need someone watch light for you, or if you have a long double wire, you can take test light wherever you are checking.
โJun-23-2013 02:01 PM
kennyzzz wrote:
ok it's the main fuse that's on the outside 12 camper battery.
camper was ok for 2 days in the driveway, walked in side camper. fridge light is... check fuse on outside 12 camper battery, try new fuse it blows out. ok turn off all 120 volt breakers, thinks that might have something to do with it.
blow another fuse,
pull all 12 volt fuses in the panel ,,blow another fuse,,
un plug fridge 120 volt..blow another fuse
i'm lost on what to do ,
no 120 power to the camper, all 12 volt fuses pulled, but still blow another fuse.
only have 1 day till trip.
looking for help.
notes
it has not rained in 5 days,
it ran for 2 days then problem. never had a problem with this the camper.
lost on why it's blowing fuses.
โJun-23-2013 07:34 AM
kennyzzz wrote:BFL13 wrote:
Yes, isolate one thing at a time. The jacks and slide have their own wires ( with 30a fuses) to the battery, not going through the fuse panel.
Do try for 12v on shore power with no battery at all. This will answer many questions
shore power is fine . just no 12 volt
โJun-23-2013 06:22 AM
โJun-22-2013 10:11 PM
โJun-22-2013 07:15 PM
โJun-22-2013 07:05 PM
โJun-22-2013 05:23 PM
โJun-22-2013 05:10 PM
BFL13 wrote:
Always suspect the last thing that was touched. What have you done with the battery or nearby in the two days you have been getting ready? What wires have you connected/reconnected?
โJun-22-2013 05:03 PM
โJun-22-2013 04:58 PM
