Can I double up on wire?
Naio
Doing this on the megawatt made me wonder: I have a bunch of 8/4 wire, nice and flexible, in heavy housing. Could I run 2 pos and 2 neg, and use it for my battery connections? 2x 8ga = what gauge?
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
21 REPLIES 21
time2roll
No person in their right mind will connect enough #8 to go 4/0 :R
That would be 13 wires, 13 fuses and a nice bus bar.
Get the right stuff already.
211592 / 16509 = 13
MEXICOWANDERER
AWG circular mil chart?
DiskDoctr
SoundGuy wrote:
The OP is asking about doubling up 8 gauge cable - so what's the problem? :h
No problem, but the table is of limited use if it doesn't support the larger gauge wires, which would seem to be a common need for our fellow RV'ers ๐Ÿ˜‰
(I know I was looking at the same info not too long ago and intended to save a few helpful links, like calculators :C )
MEXICOWANDERER
Permutations Sound Guy.
The forum is and was ripe with permutations for just about any post.
They're great for learning but permutations must have objectives pointed out exactly what you did. Self regulating threads are great but re establishing OP objectives IMHO is vital. Done right such treads are treasure troves. At risk without corrective comments is losing the OP and followers.
SoundGuy
Hiking Hunter wrote:
Use this chart.
SoundGuy wrote:
Here's an even easier to use Wire Gauge Combination Calculator.
DiskDoctr wrote:
Yep, easier, but only goes up to effective size of 1 AWG. No x/0 gauges ๐Ÿ˜ž
2012 Silverado 1500 Crew Cab
DiskDoctr
Use this chart.
SoundGuy
Use this chart.
brulaz
BFL13 wrote:
Bobbo wrote:
Be sure each wire, alone, is sized to carry the entire load. That way, if one of them loses connection, you won't have a fire hazard. The second wire in that scenario is merely to reduce voltage drop.
You can also fuse each wire so if it gets all the amps, its fuse will blow.
That's what I did with my Meanwell.
Had exactly 3 free slots in the STC fuse holder, so a 7.5A fuse for each of the 3 wires from the Meanwell, covering its max of ~16A.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
BFL13
If a fatter single wire would need a 300a fuse, you can put a 300a fuse on the positive battery post and run two thinner wires to that fuse, or you can put a 150a fuse on each wire and put the two fuses on the battery post.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
MEXICOWANDERER
How much izza "bunch"? I've got some DLO 4AWG that maybe I can tradeya. DLO is the finest quality non airplane wire on the face of the earth.
time2roll
Naio wrote:
That is not as good as I thought.
So twist all four together and the cable becomes one wire ๐Ÿ˜‰
Or you could get the right stuff.
http://www.genuinedealz.com/marine-wire/marine-battery-cable
Fully custom cables are a great value with the correct wire, proper lug, pro crimp and heat shrink.
Bobbo
Bobbo and Lin
wa8yxm
Artum Snowbird wrote:
Sure you can. Can you get all the wires under the lug at both ends though?
Another thing is if one wire is even a little bit longer the current won't be balanced,,, BUT if you have enough wire.. no problem.
IE if you are likely to pull a max of 200 amps, and your wires are rated at 100 amps each, and you ran 3 or 4 of 'em.. NO PROBLEM.
folivier
And if the extra wires won't fit on the battery lug then something like this works well:
https://www.amazon.com/gp/product/B00HZU42Z2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
