โDec-19-2019 09:02 PM
โDec-20-2019 06:20 PM
opnspaces wrote:
Another thought while the machine is down. Consider taking the hard to replace sprocket to a machine shop to be replicated. It may not be cheap figure $200 - $800. But if it's your business income it might be worthwhile to have a replacement made.
โDec-20-2019 05:54 PM
Dusty R wrote:schlep1967 wrote:Naio wrote:
The machine requires quite a bit of power and torque. When I used a 100 amp fuse I sometimes blew it. I now have a 200 amp circuit breaker which I have never blown.
For some reason this bothers me more than anything you might do to make your sprocket work.
Did you happen to upgrade the wire when you "upgraded" the fuse?
X-2
Dusty
โDec-20-2019 05:29 PM
โDec-20-2019 05:08 PM
โDec-20-2019 09:11 AM
โDec-20-2019 08:45 AM
Naio wrote:LOL
This is for my shave ice machine.
โDec-20-2019 08:30 AM
โDec-20-2019 08:29 AM
โDec-20-2019 08:11 AM
โDec-20-2019 07:37 AM
Naio wrote:
I talked to the people at the local sprocket shop where I am, and they said they thought I could use my keyed sprocket on the D shaped shaft. They suggested just tightening the set screw real well on the flat part of the D, and maybe even using a drill to make a dimple there.
โDec-20-2019 07:02 AM
โDec-20-2019 07:01 AM
โDec-20-2019 04:27 AM
โDec-20-2019 03:18 AM
