Can rough roads create a suction from the water tank vent?
Pangaea_Ron
I have been driving some windy and hilly roads on Highway 101 on the Oregon Coast with the MH, and it seems that I have lost water from the water tank. Can surging water in the tank leak out the vent tube and create a suction that would drain water from the tank? It seems to do that if I overfill the tank?
I noticed that a bit of water was dripping out the vent tube when I stopped at a view point.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
19 REPLIES 19
rockhillmanor
If I fill my tank all the way to where it comes gushing out the fill opening, yes when I hit the road it sloshes around and comes out the overfill and down the side of the RV.
I make a point of NOT doing this anymore because of the concern of other people/cops when you pull in to fuel up and they see something dripping from the MH and need to point it out to you and ask concerning questions. :R
Pangaea_Ron
Thanks all for the responses.
I think that I can visualize water sloshing out, but probably not siphoning... although some of those corners were pretty impressive just south of Yachats. My wife gave me a side glance or two.
I like the idea of a plug or valve in the vent tube while underway. Are there any issues with pressurization while using the pump?
BruceMc
The vent tube is connected to a nipple at the top of the tank - no way it could suction the water out, but it is an outlet for sloshed water. I have a tapered plastic plug I use to plug ours while underway. We still have some loss as the fill is a couple inches higher than the top of the tank, and the fill cap doesn't seal very well.
Could be what you are experiencing on rough & curvy roads too.
2016 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Beartoo
I installed a valve to close the over flow after I fill the tank.
DH - Bear
DW - Marge
Buster - English Springer Spaniel
Molly - English Springer Spaniel Puppy
07 Silverado 2500HD, Dmax, Allison Trany
Husky 15K
2008 Wildcat 24RL (Old Camper)
2009 Open Range 280 RLS (New)
Mandalay_Parr
I suppose it could. Mine will siphon out a little if I fill it too full.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
