Oct-27-2014 09:30 PM
Mar-14-2019 10:55 AM
MEXICOWANDERER wrote:
Where in the world did you get the idea I took offense?
I just find it difficult for my fingers to connect wires together with no clue as to the possible outcome. PS: The most challenging of all my curriculum was Celestial Mechanics. The dullest was forensic auditing. The most tedious was chemistry.
Then I found chemistry and electrical melded perfectly with lead acid batteries the MBA reined in a proclivity to expend tempting over-budget dollars for even more test equipment and Celestial Mechanics piped in when I peered outside and found the stars in the wrong place (spending all night on a stool crunching numbers).
My economics exposure led me by my nose on a trail to the Skunkworks auction buried deep in a technical magazine -- .50 pound for brand new space shuttle wire (Just a guess but 5-7 tons total wire purchase would be a fair estimate*) and of course the 15Kw PW+Analog generator waveform generator. The penalty for nerdiness was 100% devotion to educating myself with full-time work and no play except for horsepack trips.
*I sold perhaps 1-1/2 tons of brand new Teflon FAA/PMA certified wire at $4.00/lb. 800% markup. And a job with Lockheed unsnarling a bogus maintenance battery charger for their lab power supply.
The net sum total? Caution. Not some gyro gearloose attitude.
Kelley's Law
Murphy Was An Optimist
Mar-14-2019 10:34 AM
Mar-14-2019 06:27 AM
Mar-13-2019 11:37 PM
Mar-13-2019 11:09 PM
burningman wrote:
What has mechanically syncing large generators got to do with the price of tea in China? I don’t think that was the question.
These small inverter generators are self-syncing.
I’ve connected Yamahas and Hondas. I’ve also connected various different size units.
There’s no different-brand issue.
Do you worry about plugging your equipment into different brand generator’s power?
Do you think your microwave or computer operate differently on Honda 60Hz 120VAC than they do on Yamaha 60Hz 120VAC?
No!
It works fine. The generators don’t know or care where the other source of 60Hz 120VAC is coming from, it is what it is.
Don’t waste an extra $100 on a Honda “Companion”. That’s marketing BS. It’s zero different other than having a 30A twist-lock outlet on its panel, which doesn’t help you anyway because it’s not an RV-30, so you’ll be using an adapter anyway.
You gain absolutely nothing.
What I’d do it if were you is get another Honda, a new EU2200.
It’ll cost less than the 2400, it weighs a lot less, and when you parallel it with your existing EU2000 you’ll have plenty of power.
Harbor freight sells a rather nice parallel box. I’ve always made my own but at their price if I needed one today I’d just buy theirs.
Parallel kit
Mar-13-2019 11:06 PM
I learned early on that sending smoke signals to my bank balance is bad juju.
They do not moniker "engineering" as a "discipline" for nothing. When data is insufficient, I balk.
I do not know how to diagnose a DC motor inverter, but sure as shooting the cost of a couple of repair items would equal the cost of a new complete generator.
I defer to someone else :R
Mar-12-2019 07:48 PM
Mar-12-2019 06:35 PM
All wise words. Maybe all the ones I used shared the same cheap chinese inverter chipset. As I said, I don’t know how or why, I simply started with "what would happen if we...". A few week later I was connecting 4 of them.
What I did find amazing it that they will level load to capacity. A 3500 and a 2200 won’t share equally, but proportionally. A higher load would go to the 3500.
Interesting.
Being an EE I am far too timid to undertake a "Shake the jar Dewey and see if they fight" approach to investigating compatibility of electrical events.
Mar-12-2019 05:49 PM
Mar-12-2019 11:05 AM
Mar-12-2019 10:19 AM
MrWizard wrote:
Inverter generators from different MFG, using different electronics to create the output power are not safe too connect together
Stream driven or water driven hydro turbines are synced by brute force
They bring them online by slowly applying load ( connecting to system thru inductive load) and using the back EMF to drive them into alignment aka synchronous spinning
Something you cannot to with consumer grade ( inverter output ) portable generators
Mar-12-2019 09:45 AM
Mar-12-2019 06:23 AM
As Mr Wizard pointed out years ago, grid tie generators have the luxury of lead/lag pull-in via 1000x the energy in an established wave form.
With a 40KW John Deere/LIMA and a 40 KW Perkins/Stamford
And an owner utterly convinced that synchronization was "as simple as pie" he scoffed at my cost estimate to make the units play nice.
So he made his own paralleling 240 incandescent lamp setup.
He threw the switch (I wasn't there)
The Perkins Stamford started oscillating, from what I heard the oscillations rapidly became out of control. Oscillating means out-of control surging.
Both voltage regulators fried which threw them off-line. The primary exciters overloaded and they too destroyed themselves.
These were manual throttle control voltage regulated generators
I have a question to ask
Do you think there is some sort of peace treaty between inverter generator manufacturers that inhibits them from suing another manufacturer for patent infringement regarding any component dealing with voltage regulation and inverter designs?
Regardless
Are you willing to risk your generator or anything connected to it in an attempt to synchronize untested theory?
Mechanical synchronization is an art. To assume a second different generator can gather data then process it is a rather large assumption.
I can't help but remember Washoe Medical Center chief engineer Dwayne Telecky standing at the curb of east fourth street in Reno NV wondering how a V-12 Caterpillar engine and KATO generator jumped 50 feet through a cinder brick wall in flames (the coolant was flammable). I was on hand months before to see the operation of a six figure auto-start system and paralleling circuit. The load-shed was integrated and just conceptualizing it's entirety gave me a headache.
I believe contacting the OEM tech departments is in order. If even one says "no" I wouldn't try it.
Mar-12-2019 03:36 AM
map40 wrote:Real life trumps all the other speculation.
I have connected any of the following in any configuration:
2 3500 Predator
1 2200 Predator
2 2200 Roybi
3 different regular inverters
They all get in sync when you connect them. Even when running under load. I could start both ACs in my 36 feet class A with a 3500 and a 2200 and then move the 2200 out for a few minutes, bring another one and connect it later, and the load would automatically balance between the two units, according to capacity. Don't ask me how, I don't know.
As a matter of fact, once for a Relay for Life event we had 3 RVs (1 A and 2 Cs) and 4 Inverter generators. We bridged them ALL and connected the RVs to them (Gen 1 - C - Gen 2 - A - Gen 3 - C - Gen 4). We were able to shut down one at a time, refuel, let it rest and restart and move to the next without a glitch.
Of course, we had to make our own parallel adapters, which took all but 30 minutes.
