โDec-29-2019 06:12 PM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โJan-18-2020 07:22 PM
โJan-18-2020 07:08 PM
BFL13 wrote:
We just had a thread on that, where ISTR the pros said it was a bad idea due to brass and aluminum issues.
โJan-12-2020 04:49 PM
Larry CAd wrote:
Yeah, probably shoulda read the other responses.
โJan-05-2020 06:39 PM
โJan-05-2020 06:07 PM
MrWizard wrote:
My plastic plugs from the Amazon link arrived Thurs afternoon
Installed a new plug today
No more leak,
โJan-05-2020 01:51 PM
mikestock wrote:
I apologize that I have not read all the responses so if I duplicate others it is not on purpose.
I have winterized my various RV's for 30 years but not until 3 years ago did I do so by compressed air. I bought a $100 butterbean compressor, which has held up well. I just attach it to the water inlet, empty the water heater by removing the plug, bypass the water heater and set the compressor on 65 psi. I run the compressor as I turn on each water outlet on, one at a time and let it stay open until there is no water present. This includes the washing machine. Only pour the pink stuff into each drain trap and a small amount in the washing machine to run it through the drain pump.
I have a domestic refrigerator and have to disconnect and drain the ice maker line.
This is easier, cheaper and quicker than the old method with the pink stuff.
โJan-05-2020 10:35 AM
โJan-04-2020 06:36 PM
โJan-04-2020 05:20 AM
โJan-02-2020 05:59 PM
โJan-02-2020 05:19 PM
Old-Biscuit wrote:
IF you want to really move the crud out......remove the drain plug and turn water supply ON.
Cold inlet dip tube points down...full pressure will stir the bottom of tank up and BLAST it out the drain hole (especially on an Attwood with only a 1/2" hole)
โJan-02-2020 09:59 AM
drsteve wrote:deltabravo wrote:
I've had less than stellar results with the anode rod / petcock drain plug device
The petcock self destructed and became useless
I don't like the reduced flow on these. Seeing one fall apart is just another reason to stick with the nylon plug, IMHO.
โJan-02-2020 07:09 AM
โJan-02-2020 06:03 AM
