โJun-03-2019 08:29 AM
โJun-05-2019 02:28 PM
โJun-05-2019 12:16 PM
โJun-05-2019 11:50 AM
โJun-05-2019 11:35 AM
โJun-05-2019 10:57 AM
Workinprogress wrote:The older Magnateks had unregulated and unfiltered outputs, so it could be a little tricky to correctly measure what it's putting out. You'd need a true RMS meter at the least, and I wonder if it's even that simple? The darn thing could just be old and worn out, too.
Well, I threw it on the bench last night and found it putting out 11.8v and 32a... not exactly what I had expected to see, is that normal for the Magnatek 775? I expected 13+v and ~75A to a pretty discharged battery...
โJun-05-2019 05:52 AM
โJun-05-2019 05:32 AM
โJun-04-2019 08:34 AM
KMLsquared wrote:
I added a PD converter and wired it directly to the batteries but left the old junk in place, just disconnected, as a backup in case of failure.Workinprogress wrote:
6 hours in the compartments of the trailer later.....
-Removed Magnatek Converter. Why have two. I didn't even test it yet, I will bench test later and report back on that..
- Cleaned up wiring job on the newer PD9130.
- Opened Generator Transfer switch to ensure cleanliness, etc.. All was satisfactory.
- Started post maintenance testing and discovered the following: When generator ran I had 12v in coach, on battery power I had 12v in coach, and while plugged in to shore power I now have 12v in coach. I did not do anything other than re-position things and disconnect the old Magnatek Brick... so why do I now have 12v on shore power but I did not before? Is it possible that the two converters were fighting each other or maybe the magnatek converter was truly junk and back-feeding the transfer switch and not allowing it to close in the contacts for the shore power?
Anyhow, everything works, everything looks neat and orderly, and I am happier that it is all simplified now. I will bench test the old Magnatek converter tonight just for piece of mind (science experiment findings to follow)...
โJun-04-2019 08:15 AM
โJun-04-2019 07:35 AM
โJun-04-2019 07:31 AM
โJun-04-2019 07:10 AM
โJun-03-2019 03:09 PM
โJun-03-2019 11:22 AM
