โMay-30-2019 10:25 AM
โJun-05-2019 04:19 PM
Roger10378 wrote:
To change to 240V would be a lot of work as most if not all RV electric panels do not have 240 available. You would have to change to a house panel and then upgrade the wire from the breaker to the water heater
โJun-05-2019 04:14 PM
pianotuna wrote:
Hi,
I think the intent of using a 240 volt element is to reduce the wattage, and lower the number of over load trips at the shore power breaker.Cummins12V98 wrote:
30A does not provide 240V only 120.
โJun-05-2019 09:39 AM
โJun-05-2019 08:05 AM
โJun-05-2019 07:53 AM
โJun-04-2019 11:17 PM
โJun-04-2019 10:06 PM
theoldwizard1 wrote:
Most 120V heat elements are about 1500W so they are well less than a 15A draw. Has anyone installed a 2000W element or even a 240V 5500W (2250W @ 120V) element ? Both would require a 30A or 50A shore power connection AND some upgrades to the wiring (at least 12 gauge wire) and breaker inside your RV.
โMay-31-2019 03:51 AM
โMay-30-2019 04:04 PM
โMay-30-2019 01:01 PM
โMay-30-2019 12:38 PM
โMay-30-2019 11:56 AM
โMay-30-2019 10:50 AM
โMay-30-2019 10:44 AM
