Apr-02-2021 11:33 AM
Apr-10-2021 08:51 AM
Apr-02-2021 08:39 PM
BFL13 wrote:jimdmorrison wrote:
https://letusdisagree.com/wp-content/uploads/2021/04/circuit.jpeg
Has the #'s 1 21130
I need to replace my circuit board, but the replacement one I got was too big and didn't have screw holes in the right place. Any recommendations on which one I should be looking for? I need the screw holes to mount it or it will touch the metal.
The photo in the OP is of a 6300's fuse panel as seen here:
https://www.bestconverter.com/Magnetek-Upgrade_ep_26-1.html
Apr-02-2021 06:47 PM
Has the #'s 1 21130
Apr-02-2021 06:25 PM
BFL13 wrote:
Ok, so that one has single red pos and white instead of single blue pos and white that go to the DC panel. If it is a 6300 panel, jumper the two pos terminals and put the red wire on one of them.
Apr-02-2021 02:51 PM
Apr-02-2021 02:36 PM
BFL13 wrote:
Yes, but the issue is the 6300 'split'-- DC fuses of the 6300 between ones that need the battery as filter and the others that don't. You want to put the pos wires in the right places. if you use a 6300 panel with a deck mount converter that has its own RP fuses, you jumper the panel's two pos terminals now that all fuses are getting clean power.
Don't know for sure any of this applies to the OP's choices--why that panel doesn't fit. Maybe it is not even a 6300!
jimdmorrison wrote:
The new one I got is just a little too big. I'd rather buy something that fits better so I can close the lid.
This was the part I replaced originally, but accidentally broke the circuit board when I was working on it.
https://www.amazon.com/gp/product/B004A34G94/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
CLICKY LINK FROM ABOVE
Apr-02-2021 02:28 PM
Apr-02-2021 01:34 PM
BFL13 wrote:
Looks like for a 6300. No RP fuses. the 7300 has the RP fuses on the Dc panel. Also the 6300 has the "split" for taking three wires (two positives-red and blue) while the 7300 uses just two (one blue pos)
I don't know how you would handle the split using a 7300's on a 6300. The blue pos goes on the top middle there, so the red goes in the pos set-screw lug. I guess the RP fuses would just be gravy.
Apr-02-2021 01:27 PM
Apr-02-2021 01:13 PM
Apr-02-2021 01:12 PM
dougrainer wrote:
That looks like an OLD Magnetec 12 volt converter 12 volt fuse panel. Now it is a Parallax Power Supply 7345 model. Yours must be more than 20 years old. You will have to adapt or drill the correct mount holes and use nylon washers to stand off from shorting the back metal mount. If mine, I would line it up on the existing metal mount back and mark the mount screw holes and then use 1/4 head inch self tapper screws. Doug
http://web.archive.org/web/20200228080803/http://parallaxpower.com/wp-content/uploads/sites/8194/201...
Apr-02-2021 12:49 PM
Apr-02-2021 12:24 PM
Apr-02-2021 12:12 PM
