Coach battery charger/tender.
CoeyCoey
Hello all,
I was wondering what you all do for keeping your coach battery charged? My RV didn't come with any charging for the coach battery when on shore or generator power. The coach battery always seems to go dead after a couple weeks, so I want to find a way to charge it when on shore power. Right now, I just use a battery charger plugged into the 120 and then into the cigarette lighter. But I want to install something out of sight. I am not sure what would be better. Installing a 120 volt charger and running a 12V line to the battery, or just running a 12V line from the house battery to the coach battery with a diode and a solenoid to disconnect during starting. What do you all recommend?
20 REPLIES 20
mlo166
To bfl13: here , we have the E-450 Coach House 231 (23 ft) with a 80 amp battery isolator (abt $70) installed from the charger. In other words, the shore powers the charger then splits to the chassis battery and to the coach battery. Most OEM shore powered chargers will max out at 45 - 80 amps anyway. Use at least the same gauge wire (as from the charger) to the chassis battery from the isolator. Simple. Hope this helps for an alternative solution. Tom
wa8yxm
Two things. Battery tender you can get all over everywhere but this takes 120 volts.
Trick-L-Start (google it) Simple 3 wire hookup. provides teh reverse charge for the isolator system. Same as rigs with B.I.R.D.s have so the house converter does the job. No outlet occupied.
pnichols
This is what I've used 24/7 during storage to maintain our motorhome's engine starting battery for years - and as needed on our residence backup generator starting battery and on our garden sprayer's battery: https://www.amazon.com/BatteryMINDer-Model-12117-Maintainer-Desulfator/dp/B000P23HZS
2005 E450 Itasca 24V Class C
pianotuna
Nomad II
Nomad II
My trik-l-start has behaved flawlessly since 2013. It is a diode based product. If the amp-l-start had been available, I would have ordered it.
I blame the ten year lifespan of the marine starter battery on the trik-l-start combined with solar based charging.
Regards, Don
Cydog15
time2roll wrote:
+1 for Trik-L-Start (or Amp-L-Start)
Keeping my truck battery charged from the trailer solar power for many years now.
Noticed most vendors have stopped selling them. Something going on. When I saw Best stopped selling them, and rvupgrades, I knew something was up. I got one and it quit working.
RJsfishin
When in storage, I have always parallel them all (L/A) together,....let the PD take care of it.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
time2roll
beemerphile1
Works best if you use common nomenclature;
starting battery is the chassis battery
the RV battery is the house battery
Commonly the charging system of a MH does not charge the chassis battery.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
CoeyCoey
Janss wrote:
I've had Trik-L-Start on my coach for a few years. That's the little brother to Amp-L-Start recommended by pianotuna. It works great! I stay multiple months plugged in at one RV park and when ready to leave, the engine starts right up. Keeps the engine battery at 12.6 or 12.7 all the time.
That will probably do me. The radio draws less than 5 amps, so I should be good with the Trick L start.
BFL13
I would ask the Li guys on here if it is ok to parallel one with some other battery. (Balancing?)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
CoeyCoey
BFL13 wrote:
What is a "smart battery" ?
It is a lithium ion battery that has a built in BMS, so it is a straight swap for a lead acid.
CoeyCoey
pianotuna wrote:
Hi,
Add an Amp-l-Start:
http://www.lslproducts.net/ALS_Overview_Page.html
That is perfect! Thank you!
Janss
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
BFL13
CoeyCoey wrote:
Oh, I forgot to mention, the reason I want to wire the house and coach batteries is because I want to be able to turn on the car radio and listen to it for extended periods. At present, the battery charger does not provide enough amps to do this alone, so the battery still drains. Not worried about the float voltages as the house battery is a smart battery, and also the alternator charges the house battery when driving. Currently, the charger I have is 2 amps which is higher than most battery tenders.
Same thing in our Class C, where the entertainment system is up front and the best speakers are on the dash radio/player. I rewired the dash radio and speakers to run from the house batts, but it was a chore to route the wires.
I still need the battery maintainer to the engine battery though.
Photo in Profile
