coachman b 454
kansanforlife
have a93 coachman classb w/454 eng need exhaust man. fixed. What kind of cost?
3 REPLIES 3
jolooote
Had a Itasca for 11 years. Manifolds would last about 9 months. Replaced em 1 at a time B4 I was told the OEM's didn't have a GASKET. Bolted straight to the head. The only fix is to replace with headers & BEST gasket or to Buy the BEST, METAL aftermarket gaskets U can buy. Other Issues U WILL suffer... Hot Start problem, the starter motor gets too hot when stopped 4 a short time, like at a gas station. Its TOO close to U'r cracked(lol)manifold. Won't restart,about 45 min.)until it cools down. If U have the famous, belt driven Air pump thats s'posed to blow air into the exhaust to 'Reburn' gasses, REMOVE it. Easy to get shorter belt to fit. Plug off or just pinch off the air tubes going to each cylinder. When U remove the rite side manifold, check the exhaust pipe 'Butterfly' valve. Its probably stuck CLOSED. Remove it. Also, try advancing Timing to about -15 degrees or just B4 it starts to Ping. Much better HP. Install 3 or 4" DUEL exhaust!!!
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
Clay_L
I got a quote ten years ago that was about $700 as I recall. It could have gone up if they had to drill out more studs than the one already broken.
I ended up going with Banks headers to eliminate any future problems.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
past-MIdirector
Best repair is to replace the factory man. with headers. A set of headers installed around $1000 if none of the bolts break off. We had a man. on our 91 change several years ago and it cost $300 for one side.
