Coleman AC
Oldcoots
I have a Fleetwood Providence 39S with two Coleman AC Roof units, the rear unit will not come on. It's almost like it is not getting any power. It will not work in fan mode or AC
ANY IDEAS as to where I should start checking
1 REPLY 1
Ron_Nielson
Always start at the beginning. Check any circuit breakers that may control the a/c unit. Then check for voltage at the thermostat unit. When you turn on the thermostat, another circuit should now get voltage, if it doesn't, I'd say the problem is likely in the thermostat.
Let us know what you find.
