โJun-16-2015 12:43 PM
โJun-16-2015 07:13 PM
โJun-16-2015 06:39 PM
Hank MI wrote:
Teflon tape is not a sealant like pipe dope/sealer. It just allows the threads of the pieces to slide together easier, as mentioned without galling. End result the 2 surfaces seal together better with less force required. Use it, sparingly.
โJun-16-2015 06:37 PM
DutchmenSport wrote:
I've never used tape on PVC thread to thread connections. The female end has a rubber washer (like a garden hose) that seals the connection. If you have the rubber washer there's no need at all to use tape. (And I've done a LOT of PVC plumbing in my lifetime!)
Edit:
Manufacturer of your washing machine probably recommends no tape or putty so there is no risk of either coming loose and clogging small holes inside your washer, or that filter screen where the hoses hook up to the machine.
โJun-16-2015 06:17 PM
โJun-16-2015 06:05 PM
โJun-16-2015 05:50 PM
ernie1 wrote:
I'm confused. So the manufacturers say not to use pipe dope and some of you are saying not to ever use teflon tape on plastic pipe. WELL, what is a body to use then? Nothing? Just for the record, I use teflon tape some times and pipe dope sometimes and sometimes both. If there is a good reason not to do this please explain and then I'll follow your advice.
I was installing a shower valve awhile back and tried both teflon tape, then tried pipe dope, then tried both and I continued to get a leak. Called the manufacturer, Hansgrohe, a German company, and sought their advice. They said in Germany, because of the way the threads were cut, as in pipe threads with lateral lines cut perpendicular to them, they use hemp!! I said whaaatt? I dumped their fittings and used standard American made fittings instead. Problem solved.
โJun-16-2015 05:00 PM
โJun-16-2015 04:32 PM
cbshoestring wrote:
TAPE
Just do not over do it. Couple wraps, screw em' together. Get carried away with the wrapping---crack.
RLS7201 is correct in saying that manufactures say DO NOT use tape. However, BRUCE the plumber has probably learned the hard way that not doing so frequently results in a leak.
Where Not To Use Teflon Tape:
โขAny Gas Connections or threaded connections with a built in rubber seal.
โขFlared Fittings
They tend to have a buit in SEAL.
Threaded gas pipe use cement.
Permanent PVC/ABS connections---Glue
Correct me if I am wrong--Bruce.
โJun-16-2015 04:10 PM
โJun-16-2015 04:04 PM
โJun-16-2015 04:03 PM
โJun-16-2015 03:22 PM
โJun-16-2015 03:02 PM
โJun-16-2015 03:00 PM
