Converter abbreviations question
96Tony
My Wyco (WF-8955PEC)has the following abbreviations, also (hopefully!)pictured below.
I know most of them, but am wondering about the Rec/Con breaker, and the LP fuse abbreviation.
I'm trying to cut power to the radio, with it's bright blue dislay light, as we are going dry-camping.
The unit may be fused by 8, 9, or 11...which are all unlabeled but have 15 amp fuses in them.
Breakers:
Main
A/C
GFI
Micro
Rec/Con
Hot Water
Fuses:
1. Kit
2. Bed
3. Bath
4. Fur
5. Ref
6. TV
7. LP
11 REPLIES 11
Raymon
My radio had a way to dim the display lighting. I don't remember how to do it, but the radio's owner's manual described the procedure. Not sure the light would draw enough current to warrant concern.
Ray
SoundGuy
96Tony wrote:
Soundguy, I did pull fuses one at a time...but the darn blue display light never went out! Maybe I didn't wait long enough after pulling the fuse?
As I said, the solution is simple - install a kill switch. Pull the radio out, locate the wires feeding + 12 vdc to both the radio itself and the radio memory circuit and wire them both through a simple SPST switch.
2012 Silverado 1500 Crew Cab
BFL13
Usually, the radio and the LP alarm are direct to the battery and stay on when you pull the battery disconnect switch. So the radio clock and settings stay on. On ours the radio fuse is up by the battery in a separate little fuse panel. Our LP alarm is on that same 15a glass fuse plus it has its own little glass fuse (1a ISTR) by the unit itself.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
96Tony
Thanks, doug, I will look for the ATC fuse and try to kill just the radio.
SoundGuy
I'd guess 12 vdc power to the radio is the same feed that powers the television and the wall plate that powers the antenna head it but it's a simple matter to find out - just pull fuses 'til you find the correct one. That said, if you're going to dry camp on a regular basis I'd suggest that instead of pulling fuses you wire in kill switches to the devices you want to completely disable, just as I did. Since the object of the game here is to minimize draw down on the battery when dry camping don't forget to turn off the fridge climate control circuit, if your particular fridge has one. Plus the obvious - running LED bulbs instead of incandescent will significantly reduce battery draw down.
dougrainer
Your Radio will be on a circuit that has other 12 volt appliances on that circuit. There are only 4 screws that hold the radio in the cabinet. You will find a ATC fuse on the back of the radio harness. Just pull THAT fuse to kill the radio. If you do NOT see the 4 screws, they are behind the side covers of the radio. Those side covers just pop off, pull them outward. Doug
96Tony
Thank you!
GMandJM
Detector! Much better idea, BFL.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
BFL13
Rec/Con would be a 120v breaker that does the receptacle circuit and also the converter.
LP fuse (12v) would be for the propane alarm found down at floor level.
Photo in Profile
GMandJM
Rec = recepticals
Con = converter
LP might be for the igniter on your fridge
96Tony
Hmmm..."preference setting" not allowing me to post pics.
I'll have to figure that out.
