Converter breaker trips..Help company coming tonight
JESTER7406
Howdy all. I recently replaced my old broken converter with a progressive dynamics 4645. I followed the directions to a T. All worked well for a couple of days. That was 3 1/2 weeks ago. I just got home from work and went to fire everything up. The converter breaker was tripped and continues to trip when reset. No 12v anything working. 120v all fine. any ideas where to start.
Did I mention that company is coming tonight?
Ha.
Thank you,
Jesse
Happy Trails,
Jesse
2006 Cheverolet 2500
17 REPLIES 17
Bobbo
pianotuna wrote:
Hi,
Try disconnecting the negative battery cable. Does the breaker still trip?
Good question!
Bobbo and Lin
pianotuna
Nomad III
Nomad III
Hi,
Regards, Don
Bobbo
You have got a short circuit somewhere in the converter circuit. You probably need to pull the converter out and check all of the wiring. In the meantime, get a 50 amp battery charger, put it on the batteries, and plug it into the (working) 120v system. That will get you through the night.
Bobbo and Lin
