โAug-13-2013 12:27 PM
โAug-24-2013 06:10 PM
crankshop1000 wrote:EldIr wrote:crankshop1000 wrote:
I need to shut the fuel valve on mine too.Bouncing on the road is enough to flood the carb if the valve is left open.On the carb,there is a hidden low speed jet under the plastic cap by the choke on top.You need to pull the plastic cap off to get to the jet and blow it out with compressed air.The cap goes right back on after cleaning.That will solve your starting issues.
Thanks, I'll make note of that for when I put it in storage for winter.
Speaking of winter, what is your crankshop 1000 in? Drag sled? Trail sled? Do you go to the UP much? I trail ride an XCR800 and just got an M20 Airwave skid to put in. I know summer is short, but I'm already looking forward to winter!
Drag sleds.Prostock 1000 cc. Just a hobby runs 5.40 seconds at 125 mph 1/8 mile on ice.Used to go on a 10 day trip from the bridge to Newberry,to Copper Harbor,to Hurley Wisconsin,to Mackinac Island and back to the bridge.Haven't done that in about ten years,kind of got out of trail riding when everybody thought they needed to run the trails at 75mph.
โAug-21-2013 01:16 PM
โAug-19-2013 07:17 PM
โAug-19-2013 02:22 PM
โAug-19-2013 06:30 AM
โAug-19-2013 01:53 AM
โAug-18-2013 06:17 PM
LittleBill wrote:EldIr wrote:jasult wrote:
To the OP, you have a dirty float needle and seat!
You can still shut down with off switch.
You should follow long term storage instructions as it says.
You have a dirty carb but it did not happen over night.
I suggest using gas stabilizer after cleaning the carb
It was brand new out of the box when the engine filled with gas. First time it was used. Maybe read the posts more closely before offering a definitive answer (with an exclamation point) that is clearly incorrect.
read the post above from Champion support, turning off a machine should not fill it with gas to the point its pouring out the carp. you obviously have a problem
โAug-18-2013 05:56 PM
โAug-18-2013 05:33 PM
โAug-18-2013 05:00 PM
โAug-18-2013 03:35 PM
โAug-18-2013 12:40 PM
PaulJ2 wrote:
Maybe not a typo but a mistatement for sure. No generator has to be run dry of fuel in the carb every time you turn it off. It's a long term storage statement that got lost in the translation.
If the engine loads up with fuel there is a problem with the float or needle and seat in the carb.
โAug-18-2013 11:04 AM
โAug-18-2013 09:46 AM
jasult wrote:EldIr wrote:
Like I said, they changed something. Page 14 of the current manual.
Stopping the Engine
1. Turn off and unplug all electrical loads. Never start
or stop the generator with electrical devices plugged
in or turned on.
2. Let the generator run at no-load for several minutes
to stabilize internal temperatures of the engine and
generator.
3. Turn the Fuel Valve to the โOFFโ position.
4. Let the engine run until fuel starvation has stopped
the engine. This usually takes a few minutes.
5. Press the ignition switch to the โOFFโ position.
Important:
Always ensure that the Fuel Valve and the
Engine Switch are in the โOFFโ position when the engine
is not in use
This is a typo for sure. Call Champion and ask, No one should follow that unless storing for extended period.
