Converter Output
silverkid
I am not real familiar with the particulars of a trailer electrical system! I have a Wilderness 5th wheel with 6V batteries and a battery disconnect switch. With the batteries switched OFF via the disconnect switch, will the converter still supply DC voltage to the trailer distribution panel when connected to shore power? My concern is with boiling the batteries if the power converter should malfunctions while connected to shore or generator power.
'03 Dodge 2500 4X4 Quad LB CTD H.O.
:C
'04 Cougar 278EFS
:B
See ya down the road...
Rig Pics
7 REPLIES 7
64thunderbolt
the only thing on mine that's directly connected is the landing gear & solar.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
time2roll
Some items might be connected direct to the battery and may no longer work if the disconnect effectively disconnects these items. Typical includes slide and electric front jack.
silverkid
Thanks guys, for your replies... I physically disconnected the batteries, plugged into shore power and did indeed have DC power without the batteries!
:C
'04 Cougar 278EFS
:B
Rig Pics
ksg5000
smkettner wrote:
No harm to try.
x2 - rigs aren't all wired the same way so what works in one rig may not apply to others.
Kevin
tenbear
mena661 wrote:
A newer RV will more than likely have a 3 stage converter which won't "boil" your batteries unless its faulty. In my MH, the converter will only supply power to the batteries when the disconnect switch is on. YMMV
X2
The converter still supplies power to the electrical panel with the disconnect switch set to disconnect.
2010 Subaru Impreza Sedan
mena661
