Feb-03-2021 03:28 AM
Feb-06-2021 04:29 AM
Feb-05-2021 07:54 AM
ivbinconned wrote:
So am I to conclude that one must go all in. If I want to go lithium then get lithium converter. If not then normal basic converter?
Feb-05-2021 06:33 AM
Feb-04-2021 10:03 AM
ivbinconned wrote:Progressive Dynamics does have a "Lithium" converter and some have a "Lithium" jumper to change the charging pattern. However all this does is to lock the converter into the 14.6 charging mode continuously. This is not recommended by lithium battery manufacturers. You would have to charge and then disconnect. Fine if you use a generator and are present while charging finishes. Not so good to just plug in and go out for the day.
The Dynamic line up does not have one that does both acid and lithium.
Feb-04-2021 09:22 AM
Feb-04-2021 02:49 AM
Feb-03-2021 07:09 PM
Feb-03-2021 07:08 PM
Feb-03-2021 04:37 PM
Feb-03-2021 03:41 PM
Feb-03-2021 02:10 PM
ivbinconned wrote:
Is it because it’s cold here in the frozen Canadian climate?
It’s a WFCO 55 amp.
Feb-03-2021 10:31 AM
ivbinconned wrote:Hardwired would be connected to a J-Box with romex. Not hard wired would have a 5-15 plug to go into a standard wall outlet.
What’s the difference there between the two 60 amp ones. The one says “hardwired”.
That’s not explained.
Is it compatible with lead acid as well?
Feb-03-2021 08:23 AM
Feb-03-2021 08:11 AM
