โJul-31-2021 09:37 AM
โAug-02-2021 06:59 PM
BFL13 wrote:Nah, we're talking about the Dynamax in this thread. Sorry for the confusion.
His sig says:
https://www.rvusa.com/rv-guide/2015-winnebago-travato-class-b-floorplan-59g-tr24274
Seems to be the big brother to the Ram ProMaster City van I did the test with. ๐ Edit--except ProMasters are Rams, so how can it have a Ford in it? Our little van has a Dodge engine and transmission
โAug-02-2021 06:57 PM
StirCrazy wrote:
what year is your coach?
Steve
โAug-02-2021 04:59 PM
โAug-02-2021 04:47 PM
eric1514 wrote:
Hi all,
The MPPT controller on my coach will deliver 14.6 volts in bulk mode which is fine. In fact itโs exactly what the specs on my GC2 house batteries call for. But when I turn on the engine and the system connects the coach and starter batteries together, the dashboard alternator light will illuminate, presumably because Ford thinks 14.6v is to high.
Couple of questions. Do I care? As far as I know, 14.6v is not excessive and the condition should only last a couple of hours until the charger drops to absorbtion mode and a lower voltage. Or, is there an easy way to reprogram the light or turn it off completely? Iโm monitoring all the batteries while I travel with an app constantly running on an old cell phone so I know whatโs going on without an idiot light. I can change the profile of the charger to a different battery type and lower the voltage to 14.2v but I donโt wanna if I donโt have to.
TIA,
Eric
โAug-02-2021 11:51 AM
RLS7201 wrote:BFL13 wrote:
So if that light on means the alternator is shut down, the only amps coming in are from the solar and batteries. Not many solar amps, so battery will run down but with the house batts also on line, that would take longer.
The solar controller would stay in Bulk but not be able to keep the battery voltage at 14.6 for long. What happens next?
In my test when the charger was removed, the voltage went back down to spec, but the light stayed on. I don't know if the alternator came back on. It did when I restarted.
Pretty simple. When the line voltage drops, the regulator does its job and sends voltage to the rotor winds and the generator goes back to work.
Richard
โAug-02-2021 10:20 AM
dougrainer wrote:RLS7201 wrote:
Well now that every one is through guessing, here is what's happening with your alternator light.
The alt light gets a + voltage from the dash when the key is turned on. The light sees a - voltage on the other lead from the alternator when the engine is NOT running and the alternator is NOT producing. When the engine is running and the alternator is producing, the light on the dash sees a positive voltage on both leads and the light is off.
Now when you solar panels gets the line voltage above 14.6, the alternator regulator shuts the alternator down and the dash light sees a - voltage on the lead to the alternator and turns on.
Nothing wrong with you MH charging system.. The light is doing what it should.
Richard
You seem to think people are guessing. Well, I am NOT guessing. My info is FACT. This is direct from Roadmaster engineers over 20 years ago. The Idiot light will work with both the Alternator zero output and OVERVOLTAGE. But, in this case, it is faulting to show OVERVOLTAGE, NOT, that the Alternator has shut down. Doug
โAug-02-2021 10:14 AM
โAug-02-2021 08:06 AM
โAug-02-2021 07:50 AM
Richard
โAug-01-2021 08:28 PM
eric1514 wrote:
Well, I'm confused.
โAug-01-2021 07:35 PM
โAug-01-2021 07:13 PM
โAug-01-2021 06:09 PM
BFL13 wrote:
So if that light on means the alternator is shut down, ...
โAug-01-2021 06:06 PM
โAug-01-2021 02:16 PM
